Results 2,531 to 2,540 of 3899
July 29th, 2012 09:42 PM #2531
The bt223 is 98% * 25 microns its nominal rating is 12 microns * 50% so it means on a single pass it will filter out 50% of particles that are down to 12 microns, The fleetguard has the same absoulute rating but they do not publish the nominal rating.
Valvoline vo106 is 98% * 20 microns. Nominal is 5 microns. You have to call But allmost to get the baldwin microlit media filters are the same rating.
July 29th, 2012 09:55 PM #2532
Thanks doc.
read somewhere posted in bob the oil guy LF3335 are 76% * 30 microns? not sure if this is accurate.
Fleetguard efficiencies - Bob Is The Oil Guy
July 29th, 2012 10:40 PM #2533
Here are some awesome pictures of cut open BT223. I dont remember anymore if these have already have been posted here.
July 29th, 2012 10:56 PM #2534
i have posted those before, also the tread you referenced is 10 years old, not a good souce for up to date ratings. I called Fleetguard to get the ratings since they do not publish them.
- Jun 2005
- 3,774
July 29th, 2012 11:25 PM #2537hey doc, so that means the purolator ace is selling is orig? I was still wondering why the L14476 that i had in stock had no crimps and country of origin. i thought it was fake but now im thinking its an asian market version.
im still using BT223 for my toyota but i still have some purolators. stopped using purolator when their authenticity was questioned. hehehe
- Jun 2005
- 3,774
July 29th, 2012 11:34 PM #2539guys, quick question, sorry got a little confused reading about good oils in thus thread.
for a vios, what is the lowest TBN i
should use? I read the spec sheet pf idemitsu eco 10w-30 from an it had only 7.8. I was thinking its kinda low, is it?
is zic oil okay for the vios? What series/type do you recommend? I read its a type-III oil so it must be good. Where can i buy it and how much is it?
im done researching on the oil filters. im now researching on good oils that are relatively low priced with good performance. i plan to use it for about 8k kms only
July 29th, 2012 11:35 PM #2540
*CB
no sir. hehehe! repost lang from the other site. ganda kasi ng pics e. ang linaw. nasasayangan din ako kung cut open ko yung unused BT223 ko. hehehe
* doc
Found it bro
http://www.modot.mo.gov/business/con...rposesONLY.pdf
Tesla Philippines
