Page 184 of 390 FirstFirst ... 84134174180181182183184185186187188194234284 ... LastLast
Results 1,831 to 1,840 of 3899
    Jan 2008
    #1831
    ^5k kms OIC with FS oil sir.
    Apr 2012
    #1832
    Just like to ask where can i find the filter base for baldwin filter in Manila. I am planning to install coolant filter, transmission filter on mitsubishi engine.
    BT839 , B5134 and maybe BD28/ bd7028 for bypass engine. Tia
    Dec 2007
    #1833
    Sir, are you referring to mineral oil change interval? how about synthetic oil?
    You can go around 10000 easily on mineral oil and 12000 to 15000 on synthetic but it also depends on the API rating. Oils like Delo 400 which are group 2 will go 12000 on a diesel so in a gas engine expect a much longer life out of it. Diesel oils are more robust and have a higher TBN so they last longer.
    Oct 2011
    #1834
    Okay, thank you for the clarification sir. So the "myth" of 5k oil change for mineral oil and 10k for fully synthetic oil is busted.
    Mar 2012
    #1835
    Quote Originally Posted by troyadam View Post
    Pacer might have the filter bases. I've bought some from them before. Just give them
    the thread and filter size.
    Dec 2007
    #1836
    It's not me that busted it that for sure, the availability of engine oil analysis to the average person has shown clearly the facts on oil changes.
    If your green, which I am not but try to be, it's much better for your environment as well, less oil used less to dispose of.
    Oct 2011
    #1837
    Indeed sir dvldoc. Not to mention savings in oil change interval. Imagine, if you have 5 or more cars..... that is already a big savings on extending the oil change interval.
    Apr 2012
    #1838
    Quote Originally Posted by Rocko24 View Post
    Saan po sila located from the thread its somewhere in kalookan?
    average how much po ang isa?
    sufficient na siguro kung filter number ang ibibigay ko? Tia
    #1839
    They're near the 5th Ave. LRT station along Rizal Ave. Some word of caution with Pacer though. We bought a couple of Fleetguard filters from them a few months back and per checkings with dvldoc and cross-referencing the pics of what we got with what can be seen online, there's suspicion it may be fake. We're trying it now with a 5000km OCI and will open it up right after to confirm whether the filter is good or not.
    Oct 2011
    #1840
    I know this has been discussed so many times before in this thread but I'll ask again. The main reason why some people change oil regularly at a short interval is to avoid the formation of sludge inside the engine. Having said that, is it bad oil filtering that causes the formation of those sludges? or is it the oil itself which at some point will degrade and sludge the engine? sa oil ba ito or sa filter?
Remote bypass oil filtration
