Results 401 to 410 of 3899
- Jun 2005
- 3,774
July 3rd, 2011 11:21 AM #401looks like i finally got the real deal. hehe.
i noticed though that the filter itself does not have the plastic that covers the thread and oil inlets. its something that im used to see in a filter. does it really come without that? the person from the shop told me its really does not have a plastic covering. is this true?
Btw, dvldoc, i saved the link you posted on the filter cross reference guide. it has tons of useful info. thanks for posting.
ry_tower thank you too. hehe
July 4th, 2011 02:21 AM #402
Most Baldwins do not come in plastic, they are in there own box for the most part especially on the small filters. Only the very large filters come in full plastic wrap because they do not come in their own box. I probably have about 100 of those BT223 in my storage so you got the real deal.
July 4th, 2011 02:33 PM #403
^thanks for clarifying that doc....I was also kinda worried about the plastic not being present....
- Nov 2009
- 3,503
July 5th, 2011 02:01 AM #404
July 5th, 2011 03:15 AM #405
I call them, I just use the 1800 number on there site, just like I do with Fleetguard. These two do not publish their efficiencies online.
It's basically the only way to get the filter specs besides doing a web search for it.
They will either give you nominal or absolute ratings depending on what they have on file. You will have to ask further if it's multi-pass or not.
- Jun 2005
- 3,774
July 6th, 2011 10:45 PM #406
hey dvldoc, thanks for the info again. was wondering what is the difference between the the bt223 and b33 aside from the physical size.
b33 is the cross reference of oem.
i read somewhere that the bypass pressure is not the same. i think 8 for the bt223 and 14 for the b33. Im not sure of the actual numbers. i prefer the bigger physical size of the 223 but im concerned on the bypass pressure.
also are all microglass filter element, say of baldwin, are the same? im thinking if its microglass, the filter element must be the same and difference would be the thread, bypass valve and physical construction. am i correct?
Thanks in advance!
July 7th, 2011 08:27 AM #407
If it crosses to the B33 use the BT223 it's a better filter than the b33. 8psi vs 14psi bypass is not a huge difference. If your OEM crosses this than it's probably closest to the factory specs.
Descriptions: Full-Flow Lube Spin-on Contains: Anti-Drainback Valve
8 PSID By-Pass Valve Fits: BMW, Chrysler, Dodge, GMC, Saab, Saturn, Suzuki, Toyota Automotive; Bobcat, Cub Cadet, Interceptor, John Deere Equipment Replaces: Chrysler 2647020; Kohler 520-5002; Lister 201-55370; Onan 122-0645; Toyota 15601-13051 Thread: 3/4-16 O.D.: 2 29/32 (73.8) Length: 3 1/2 (88.9) I. Gskt.: G449-B
14 PSID By-Pass Valve Fits: Daihatsu, GMC, Toyota Automotive, Light-Duty Trucks; Generac Generators; John Deere Equipment Replaces: GMC 25161880; John Deere AM107423; Toyota 90915-03001 Thread: 3/4-16 O.D.: 2 11/16 (68.3) Length: 3 (76.2) I. Gskt.: [1] Included UPC: 7 91440 00042 1
- Jun 2005
- 3,774
July 8th, 2011 10:36 PM #408
July 10th, 2011 09:55 AM #409
sirs,
would tyou be able to know the baldwin equivalent for a toyota fortuner 3.0D4D fuel filter?
- Jun 2005
- 3,774
