Results 11 to 20 of 76
May 20th, 2005 06:56 PM #11
sa trooper, the injectors just get clogged, thru time, u feel ur engine getting weaker and stalls sometimes until it just doesn't want to start or just dies on you while running, for me ayaw na magstart. a couple of my friends, namatayan, had to get their troopers towed pa. sa mga hi end vehicles like x5, siguro mamatay o maaffected pa yung ibang parts. sama talaga diesel natin dito,
Tsikot Member Rank 3
- Aug 2004
- 2,452
May 20th, 2005 07:07 PM #12Originally Posted by KCboy
May 20th, 2005 07:08 PM #13
how many kms have you travelled when those symptoms started coming out? this was around two years ago ba?
01 EX Ody
- 437
May 20th, 2005 09:08 PM #14ang trick dyan e nasa filtration......have an extra fuel filter installed and regularly check it. and go to one regular gas station when filling up.
- Nov 2002
- 1,326
May 20th, 2005 09:17 PM #15Originally Posted by KCboy
considering na ang lakas ng benta ng innova at napakarami ay diesel ang kinukuha... ano kaya ang plano at strategy ng toyota about this issue?
May 21st, 2005 12:05 AM #16
24000kms nun when it first exhibited the symptoms, may ginawa p asila nun para gumanda but after a few months, bumalik ulit at wala na daw sa warranty so i had to pay 47000 p to replace the injectors, u can double the filters but it would just delay the inevitable, screwed up injectors. disposable daw yun so once its clogged, palit na.
- May 2005
- 225
May 21st, 2005 08:21 AM #17i remember once a mechanic in san juan told me that if you're running a CRDi vehicle, you should stick to one particular brand of diesel, I forget which one if it's Total or Shell.
My dad is running a European vehicle with a hi-performance diesel...he's using two fuel filters and monitoring those two filters on a regular basis. Though, he claims the sound of the engine has changed a bit since he bought the car. Km reading is above the indicated 24000 expected lifespan mentioned here.
- Aug 2003
- 9,720
May 21st, 2005 08:39 AM #18pasensya na po, not very knowledgeable about this stuff. i see some shops selling fuel injector cleaners. di ba uubra to?
May 21st, 2005 11:27 AM #19
al motor,
what car are you talking about so i would know? crdi ba? not all people have the knowledge n capabilities to take the extra steps you've mentioned above. my point is sir is that most crdi engines will fail and cannot take the dirty diesels that we have po. i just hope the government and the big 3 oil companies take steps in refining much cleaner diesels.
May 21st, 2005 11:47 AM #20
kcboy:
question, what is the percentage that the fuel injector of crdi cars will break? is it 80%? because if the percentage is quite big, then that's really a problem.
