Results 1 to 10 of 16
- 36
January 15th, 2014 12:11 AM #1New owner of Diesel vehicle po ako, i bought my 2nd hand REVO last December 2013 sa PASAY Automall. Alam po siguro nating lahat na ang diesel engine ay matipid sa Fuel Consumption lalo na pag brand new. Dahil before po ako nagkaroon ng REVO nasubukan kong imaneho ang service ng opisina na 2005 REVO diesel na halos 1 araw kameng bumibyahe e kaunti lang binaba ng fuel guage meter nya kaya impress na impress ako sa REVO. Pero nong mabili ko nga yung 2004 REVO 2.4 diesel e nagulat ako sa FC ko ng tumakbo ako ng more than 100 kl from Crame to Sta Rosa Laguna then vice versa e from half yung fuel guage ko (gitnang guhit) bumagsak sa 1/4 agad (pangalawang guhit) considering na long drive yun kasi sa SLEX at walang traffic sa EDSA dahil sunday. Abay sabi ko parang EXPEDITION kung kumonsumo ah
By the way gumagamit pala ako ng 2T sa diesel ko ayon sa feedback nga dito sa TSIKOT regarding. using 2T oil para pampatahimik/smooth ng makina at less smoke, abay magandang benefits kaya ginawa ko. Pero inubos ko na yung mga diesel ko na may halong 2T baka kako yun ang dahilan. From now i will observe kung magbabago FC nya pero kung hindi sana matulungan nyo ako
- 53,883
January 15th, 2014 12:35 AM #2crame to sta rosa and back... that's about 80 km! siguro worth 6 liters yang distanciang yan.. ilang litro ba ang tantiya mong binaba ng gauge?
January 15th, 2014 12:55 AM #3
Going by the fuel gauge is simply a guessing game.
Fill it up to the first click.
Do that trip again.
Fill it up again to the first click at the same station.
Compute.
If this is the fully loaded VX with the 240D and an automatic, don't expect fuel economy to be great. Still, I suggest you check the transmission to see if it's slipping, and look to see if your exhaust smokes a lot or smells of diesel.
Also check that your oil level is not rising... which is a sure sign of fuel contamination, which means you need your pump recalibrated and/or your nozzles cleaned, because there's too much fuel going into the engine.
- 36
January 15th, 2014 10:31 PM #4I don't know sir dr. d im not aware of the fuel tank capacity ng REVO
. Kung 6 liters lang dapat sir ang konsumong tantya nyo e palagay ko sobra-over sa 6 liters ang naubos ko :sad: considering from half line sa guage meter going down to 1/4 (2nd line before Empty). Thanks for your response and inputs sir dr.d
January 15th, 2014 10:47 PM #5
if my computation is correct, assume po ninyo na 1/4 ng fuel tank ang nakunsumo. (from 1/2 to 1/4). afaik, around 40 liters ang fuel tank capacity, including reserve na po, which is below the E line. palagay ko, nasa 10 liters ang nakunsumo nyo. ang distance po ng crame to sta. rosa, nasa 100 kms yan. lumalabas na 10kms/liter ang FC nyo. depende pa yan kung saan sa sta. rosa. another thing to consider is driving habit, you might be driving like a teen-ager. malakas po ang kunsumo ng fuel pag mabilis ang takbo. however, i suggest injector nozzle balancing and replace fuel filter. baka di pa napalitan. just my 2 cents.
- 36
January 15th, 2014 11:34 PM #6
- 53,883
January 15th, 2014 11:47 PM #7
- 36
January 16th, 2014 12:11 AM #8Hopefully sir tama computation nyo, but if your facing the REVO dashboard looking at the fuel guage its not equally divided the gap/space between the 4 lines. Mas malaki ang space between half line down to 1/4 line compare sa space between 1/4 line down to Empty line. Like what dr. d have said. Thanks po sir shelu for your inputs
- 36
January 16th, 2014 12:33 AM #9Mukhang paranoid na nga ako :praning:kaka isip ng problemang yan :laughbounce: tuwing sasakay ako e nakabantay ako sa needle ng fuel guage ko hahaha! I will wait first for the result dito sa test na ginagawa ko. oh! one thing i remember ang sabi pala ng ahenteng pinagbilhan ko na na-sherif ng financing sa first owner itong sasakyan then mukhang matagal na stock sa warehouse kasi nakita ko stickers ng mga registration sa plaka from 2005 tapos 2012 na agad tsaka odo reading nya 21k :laughbounce::surprised: kung talagang na stock ng matagal pwede rin kaya maging dahilan yun? TIA mga paps
January 17th, 2014 09:23 AM #10
this is the way to go when computing for FC. Never ever rely on "my Php xxx is good for xxx kms" or "my gauge moves down from here to there when i travel this much".
It's good to do this over several tankfulls so you can establish consistency and you can tell better if you're driving efficiently or not.
Tesla Philippines
