Results 31 to 40 of 48
- Jun 2005
- 3,774
September 17th, 2016 10:44 PM #31Mukhang stored code yan kung di naman nakailas CEL
September 17th, 2016 11:16 PM #32
- Jul 2016
- 939
September 17th, 2016 11:49 PM #33High signal means short to ground
And low signal means open circuit.
Most probably dahil nga dun sa pag tangal lang ng connector. PERO, sana tsinek ng technician kung anu ang live data na reread ng IAT(ambient temp +10-20deg c. Pag maninit makina) sensor and ng MAF(sabay sa RPM pag nirev.)
mo after reset.
If abnormal pa rin, it could be the MAF nga since nandun din built in ang IAT sensor.
September 18th, 2016 06:05 AM #34
September 18th, 2016 06:15 AM #35
Sometimes due to corrosion or oxidation, signals tend to be noisy "confusing" the PCM or the signal becomes too weak. One of the solutions is to apply stabilant 22 to the terminals
http://www.wurth.co.nz/cat/files/ass...s/page0054.pdf
September 19th, 2016 09:04 AM #36
Given the above inputs, can anyone recommend me to a shop (pref. Near makati or pasay-since namamatayan ako makina), wherein kayang tyagain at hanapin sira ng kotse ko?
Yung ibang shop kasi parang proseso na kung magtrabaho eh at mukhang may isang mekaniko lang na maalam at yung iba helper lang. Pag madami na customer usually di na naaasikaso maigi. Hehe
September 19th, 2016 09:09 AM #37
Also, given na yung lumabas na trouble codes at yung symptoms, can i conclude na nasa air/intake area lang to?
1) faulty maf?
2) faulty wiring system sa maf, iac, tps??
3) vacuum leak?
Or may possibility paring nasa ignition, fuel or cooling system?
September 19th, 2016 09:51 AM #38
since you have the diagnostic trouble codes, start from there.
check your voltages at the MAF connector
blue/black battery voltage with KOEO (key on engine off)
gray/green less than 1 volt
gray/black 1.8 volts at 20 degrees celsius
2.2 volts at 30 degrees celsius
violet/white less than 1 volt
black/orange 0.7 volts KOEO
1.3 volts after engine warm up
September 19th, 2016 01:18 PM #39
September 19th, 2016 02:15 PM #40
Tesla Philippines
