Results 511 to 520 of 6552
August 5th, 2012 08:32 PM #511
Regarding oil viscosity, is it safe to assume that most diesel powered engine use a grade of "40" since diesel would likely be much hotter. Whereas for gasoline powered engines, pwede na ang viscosity grade na "30" in a tropical weather climate condition.
- May 2012
- 372
August 5th, 2012 09:10 PM #512after reading all the pages, ive read that idemitsu and zic a are good for gasoline engines. im narrowing my choice on 10w40
my engine is b16a honda civic ek year 2000. it says on the manual SG, SH or SJ. Can i use Higher Rating such as SL, SM or SN?
since wala din catalytic converter yung oto, so pwede na din po ba gumamit ng Zic UP 10w40 SL rating?
now im just choosing between:
Zic Up 10w40 or Idemitsu 10w40 combined with Baldwin Filter for honda. oil gurus, which one would you recommend?
At saan po ba nakakabile ng Zic Up 10w40? wala po ako makita sa ace hardware.
- Jun 2012
- 45
August 5th, 2012 11:10 PM #513Wow I was enlightened sa mga info nyo. Thank you very much. Just like hachooro, I'll narrow down my selection to 10W40 or a 10W30. Siguro this coming 5k pms for me I'll change to a 10W30 since tagulan na at ber months to feb ay malamig. Kung summer change to 10W40 since lagpas 30deg ang temps satin.
August 5th, 2012 11:43 PM #515
No idea about the idemitsu. Is it fully synthetic ?
Zic Up is a diesel oil. This is even better for gas engine since it has more detergents than the normal gas specific oil. Semi synthetic.
ZiC A is a gasoline specific oil. Semi synthetic.
You can PM . miko101130. He sells ZIC in the QC araneta ave area.
- May 2012
- 372
August 5th, 2012 11:54 PM #516^thanks for the reply sir, idemitsu 10w40 is semi synthetic rated SM. well since diesel oils are better i guess i may have to try the Zic up 10w40.
sir do you have any idea how much for these zic up 10w40?
August 6th, 2012 12:23 AM #518
sa susunod subukan ko rin ung ZIC. pero sa delo gold ultra muna ako sa next oil change.
August 6th, 2012 08:29 AM #519
August 6th, 2012 09:34 AM #520
Tesla Philippines
