Results 331 to 340 of 6552
June 13th, 2012 09:46 PM #331
- Feb 2008
- 898
June 17th, 2012 10:12 AM #332Mga bossing, ok ba ang engine oil na 15w40 for my Innova gasoline? Sa Total kasi me 190/liter sila at 5.5 liters yung kailangan sa tsikot ko. In another shop sabi nila yung 15w40 is for diesel engines....please clarify this for me....nalagyan ko na ng 15w40 yung engine ko....
June 17th, 2012 11:24 AM #333
June 17th, 2012 02:13 PM #334
- Feb 2008
- 898
June 17th, 2012 04:19 PM #335Thanks for the reply....But, after looking at my receipt, I notice the following description: RUBIA TIT 7400 15w40 and googled it and found this http://www.total-oil.uz/products/pds...00%2015W40.pdf
It states na for diesel yung 15W40 ang Total oil na nalagay ko. Dapat ko bang mag-drain at mag-change oil ulit immediately? By the way bago yung oil filter ko, dapat rin bang palitan?
Please help....Last edited by attyallanlatras; June 17th, 2012 at 04:43 PM.
June 17th, 2012 04:49 PM #336
Diesel specific oil can be used on gasolines. It is better this way since the diesel oil has more detergents to clean and protect your gas engine. But if your is equipped with a catalytic converter, you need to watch out for the amount of zinc and phosphorus (should be less than 1200 ppm) that the diesel oil you will be using. Most diesel oil that says "low emission", "emission system protection, etc... or are API CI are safe for the cat converter since they usually have less than 1,000 ppm of zinc and phosphorus.
Based on the link you provided, it looks safe. There is no need to drain it out, in other words. Use the oil until your next oil change.
The most damage using a really old school diesel dino oil like Petron HD on a vehicle with catalytic converter is that it would lead to cat poisoning, rendering it ineffective.Last edited by number001; June 17th, 2012 at 04:52 PM.
June 17th, 2012 05:43 PM #337
delikado lang cguro if it is the other way around ung gasoline oil rated SL/SM tapos nilagay mo sa diesel engine.
- Feb 2003
- 1,038
- Feb 2008
- 898
June 19th, 2012 03:07 PM #340
Tesla Philippines
