Results 2,051 to 2,060 of 6552
February 15th, 2014 11:09 PM #2051
A higher SAE grade does not always mean "better" protection.
Higher SAE grades are used for elevated engine temperature, for example, endurance racing.
The car's cooling system maintains a minimum and maximum temperature. It does not matter what oil you use, 5W30 and 5W40 will have the same operating temperature.
Here in the Philippines, including Baguio, the oil's cold flow grade (5W) is not that important.
Posted via Tsikot Mobile App
February 15th, 2014 11:12 PM #2052
February 16th, 2014 10:56 PM #2053
February 16th, 2014 11:08 PM #2055
Okay ba ang Delvac sa Vios?
Sent from whatever device I got my hands on via Tapatalk
February 17th, 2014 12:39 AM #2056
ok lang yan sir...
kahit anong grade pa pwede gamitin, kasi hindi naman nag wi-winter dito... so kahit 0W/5W/10W/15W ang start it will have the same protection... the difference in flow characteristics is marginal because we never get so cold here...
preference and budget lang mag determine kung anu bibilin para sa auto.
kapag cold weather(winter) 15w40 won't flow even 10W will have a hard time before flowing,
"the difference will be in fuel efficiency, 0W/5W are more fuel efficient compared to higher grades"
- Aug 2013
- 475
February 17th, 2014 07:29 AM #2057tanong ko lang Sir.
yung "cold" viscosity ng 0w40 na Mobil ay 75 cSt, "hot" naman ay 13.5 cSt
yung sa 15w40 na Mobil din ang "cold" niya 109 cSt, "hot" naman ay 14.5 cSt
kung marginal lang ang difference during cold flow, ilang percentage ba ang pinagkaiba ng 75 cSt sa 109 cSt?
base kasi dun sa datasheet, halos same lang sila ng viscosity during operating temperature. 1 cSt lang ang pinagkaiba nila.
sabi din kasi ni pareng Google, 80% ng engine wear nasa initial start up.
salamat.
February 17th, 2014 08:29 AM #2058
February 17th, 2014 09:22 AM #2059
Kung wala naman fuel or coolant dilution sa motor oil, hindi naman mawala totally ang wear protection additives ng oil sa mga bearing surfaces ng engine. Considering the ambient temperature natin, kahit 15W40 pa ang motor oil use, it will easily flow where it is needed. CS will tell us, mas mabilis siempre flow ang 0W40 or 5W40 dahil mas malabnaw pero viscosity difference at operating temp is really negligible. Best is to warm up the engine at idle for 3 - 5 minutes before you go on your daily grind.
February 17th, 2014 11:41 AM #2060
CST reflects the time required for a fixed amount of fluid to flow through a certain sized orifice on the testing device
bro, it may seem technical and overwhelming yung info and numbers, its just says na kapag mas malapot ang oil mas matagal siya makapasok sa butas... lalapot siya kung malamig ang ambient temperature... eh kahit nasa baguio pa tayo eh hindi yan aabot sa freezing temp, so it will still flow sa orifices just a little bit slower if not almost the same to 0W to 5W...
we can never eliminate engine wear during start up, unless meh mainbento na oil na hindi mag settle sa oil pan...
its like us humans, we age we get sick... so ganun din engines, it will get old and will have breakdowns.
kung meh budget ka go for fully synthetics... and dapat dilemma is to go fully synthetics or not,
hindi na dapat pag isipan nang malalim kung 5w/10w/15w... "unless you want fuel efficiency"
Tesla Philippines
