Page 130 of 656 FirstFirst ... 3080120126127128129130131132133134140180230 ... LastLast
Results 1,291 to 1,300 of 6552
    Oct 2011
    #1291
    Kung mga 5 years old na rin na gas engine puwede na. Oil thins at high temp t saglit lang sa gas engine yang w50 rating. kaya nga most motorcycle oils are w50 din required ksi nga panlaban sa init. Puwede na din. Although sacrifice ka nga lang kunti sa start-up wear kasi 20 yung first rating. Pero dahil old gas engine na, hindi na masyadong problema yan.
    For less than 5 years na gas cars, best get 10w40.
    okay, thanks for your added inputs sir ry.
    #1292
    I don't agree with this one. Although it is true that oil degrades overtime due to heat, oxidation, etc., it has much to do with the quality of oil that you use. A cheap a$$ oil will have a higher thermal degradation than a highly refined quality oil.
    Using w50 oil and assuming that it will degrade to w40 is not smart thinking. With that logic/reasoning, you should be worried, it might degrade to w20 too soon.
    Do you really want to start your car with a 20w50 oil knowing that most of the engine wear occurs during start up, especially in a gas engine?
    #1293
    Quote Originally Posted by nivraarvin View Post
    Like I said, its more of for those cars with at least 5 years of use and about 100,000kms of mileage. Not for new cars.
    Oil will thin out as temperature rises. So its not about smart thinking, it's a scientific fact. Even if you use the best oil out there, it will thin out but not as much as a good oil, that I agree 100%. Pero kelan ba ako nagrecommend ng mahinag oil dito?!
    Dec 2011
    #1294
    Quote Originally Posted by 7138 View Post
    Hindi naman siguro gagawa ang toyota ng move na makakasira sa kanila.
    hindi din naman siguro aaprobahan ng mga engineers ng toyota yan kung hindi applicable dito,
    may mga studies yan, kaya before nila gawin may basis yan.
    Don't underestimate the greed of filipino businessmen, there are a number of post here at Tsikot sharing their bad experiences with official CASA of their vehicle. Yung CASA pinapalitan ang mga piyesa ng sasakyan nila ng luma kapag nagpapa-PMS sila sa kanila.
    Oct 2011
    #1295
    Yep, be aware na lang and careful sir. Mahirap na magtiwala sa panahon ngayon kahi CASA pa yan.
    #1296
    Are you recommending 20w50 oil? For a gasoline engine? For a 5 year old/ or older car? Is that the best oil weight/viscosity for a car that type and that age that you can recommend?
    No.
    #1297
    No.
    All i'm saying is if it's a high mileage car, yes. That is an alternative to 15w40 or 10w40. It's not a directive sir, you may or may not follow it. I;m sure people here in tsikot would do their own research naman.
    #1298
    Yup you need to do some research of your own to satisfy what's in your mind
    Oct 2011
    #1299
    Nung tinanong ko sa TMB kung bakit 20W-50 ang gamit nito sa VVTi, ang sagot sa akin kung gusto niyo ho sir mag synthetic na lang kayo 5W-40.
    May 2005
    #1300
    Bec. Toyota uses Caltex products at least for their gas engine oil.
    20W-50 mineral dino oil
    10W-40 semi synthetic
    5W-40 fully synthetic
    Locally kasi ala din naman mineral oil (for gas engine specific) any lower than 20W-50 except for Honda's Idemitsu repackaged 10W-30 mineral oil.
    One alternative is to go for diesel engine specific mineral oil (but 100% compatible with gas engines). Usually in 15W-40
Mineral , semi synthetic or fully synthetic?
