Page 13 of 656 FirstFirst ... 3910111213141516172363113 ... LastLast
Results 121 to 130 of 6552
    Oct 2011
    #121
    Same price lang po yan halos if sa mga auto shop na malalaki kayo bibili. Delo Gold and R3 are both CH-4 rated, Delo Gold Ultra yung medyo nasa P190-220 ang CI-4 rated.
    Okay thank you sir. malaki pala patong sa ace kung ganon.
    #122
    Sobrang mahal sa Ace. Better get from a big auto shop. Yung ibang gas station kasi fuel lang yung direct sila sa principal kaya lubricants minsan mahal. Peor yung mga auto shop at oil stores lang mismo, mura yan.
    Oct 2011
    #123
    Thank you sir. I was in petron gas station earlier this morning and inquired about their diesel engine oil. Meron silang Rev-X Trekker multigrade mineral based oil 15W-40 which is CI-4 rated (Php278/Li). Is it on par with Caltex Delo Gold or Shell Rimula R3? How do you rate those three types of engine oil from good to best? Thank you for your inputs.
    #124
    mas sulit pala ang delo gold at Php200/Liter kumpara sa Rimula R3 na nasa Php260/Li.
    The last time I bought Shell Rimula X R3 from a Shell Gas Station near our village, which was last month for our GS's 15KKm PMS,- nasa P203 lang siya per liter.... Medyo mahal ang P260/L na nakita mo, bro.
    15.6K:weathermanf2:
    Sep 2011
    #125
    Mas okay sa climate natin and laso for older engines yung w40 viscosity. So better yang Delo Gold na SL rated naman. You don't need to worry about zinc levels since it i just about right at 1200ppm.
    Ah ok thanks. Almost 3 years na ako delo gold ginagamit sa civic ek.
    Oct 2011
    #126
    15.6K:weathermanf2:
    sa Ace ko kasi nakita ung Rimula R3 brad. Cge, tanong ko din mismo sa Shell Gas Station kung magkano. Nalilito na ako kung ano ang bibilihin kong mineral oil.
    #127
    Delo Gold Ultra ka na lang. Mura siya. Or Mobil Delvac MX basta sa auto shop ka bumili. Ci-4 rating nilalagay ng Petron pero wala yang API symbol na nagpapatunay na pasado sila. Claims lang nila yan kasi dapat may API symbol if pasado. Tsaka yun nga, problem with petron is you don't know its chemical composition. Stick to those with published product data sheet.
    May 2009
    #128
    Mas maige kung Delo 400 ka na lang kung ganyan din lang presyo ng Petron. P295/li ang bili ko sa Delo 400 (not the two Delo Golds ha).
    Delo 400 is API CI-4 plus/CI4/CH4/CG4/CF4/CF/SL afaik sa label nya plus other oil tests like MB, JASO, pati Cummins pa ata.
    TBN as per one pds is 12.6 tapos 10.5 naman yung nakita ko sa ibang pds pero i think that's the LE version which is CJ-4 na. or maybe yung 2 ASTM test yun with regards to TBN (D2896 and D4379). either way, considered pa rin na mataas yung TBN nya.
    Oct 2011
    #129
    Thank you sir, ano API rating ng Delo Gold Ultra and Delo Gold? based dito sa mga post seems like this is a good oil compared sa shell and petron.
    May 2009
    #130
    You may want to try also yung Valvoline oils sa ACE. cheap din at CI4 and cummins rated din yung mga ibang diesel oils ng valvoline. natry ko na din kasi yung valvoline turbo at P200/liter e.
    Delo Gold Ultra is CI4/SL
    Delo Gold is CI4 down to CF/SL to SF ata yun.
    correct me if i'm wrong dito sa post ko. nagbenta kasi ako lately ng mga junks sa bahay kaya wala na yung mga plastic containers ng oils.
Mineral , semi synthetic or fully synthetic?
