Results 11 to 20 of 32
August 13th, 2018 12:25 PM #11
First,
Change your shop to a competent one.
Second,
Have a scan and if possible, have a snapshot picture or printout of the Freeze Frame data.
Third,
Avoid jumping into conclusion and start replacing parts without proper DIAGNOSIS, not guesses.
This maybe a temporary condition of moist or wet ignition from the inclement weatherLast edited by jick.cejoco; August 13th, 2018 at 12:27 PM.
- Aug 2018
- 17
August 13th, 2018 04:42 PM #12I had it scan and now ihave a Check engine light which is always on... and a second problem which arrives while driving the misfire blinking check engine...
There is no mazda center here in batangas province and i cant bring it far due to the condition and its misfiring even at idle...
Scanned code are P2817 and P0301
Changed 4 pcs spark plugs and still the same...
Ignition coil checked and swapped still no improvement...
Cleaned maf sensor still the same...
Now they are changing the fuel filter and i hope its the solution...
August 13th, 2018 07:25 PM #13
- Aug 2018
- 17
August 14th, 2018 09:16 AM #14do you mean the fuel injector?
I think the problem is the o2 sensor because now my catalytic converter is now starting to have bad noise. Its like im driving a jeepney when im accelerating.
Also the mechanic said this 02 is the problem of my said model most of the times.
Is it a good idea to open the catalytic and remove all the molten parts inside? this is the advice of the mechanic to avoid changing it a new one which cost really big.
August 14th, 2018 11:28 AM #15
The HO2S is not the cause of the misfire but will give you diagnostic trouble codes, cause the malfunction indicator light to illuminate or make your MIL to blink. If the misfire reaches a treshold that is a potential to damage the catalytic converter, it will blink
- Aug 2018
- 17
August 14th, 2018 01:38 PM #16
August 14th, 2018 01:49 PM #17
The HO2S was not the cause of the misfire. As a result of an impending misfire, the HO2S will report abnormal oxygen levels in the exhaust gases and continued misfire sets a DTC. If the misfire is severe, that's when the MIL flashes to prompt you to shut down or limit running the engine to prevent catcon damage.
- Mar 2005
- 703
August 14th, 2018 03:50 PM #18
- Aug 2018
- 17
August 14th, 2018 04:44 PM #19
- Aug 2018
- 17
August 15th, 2018 07:20 AM #20
