Results 1 to 10 of 30
- Nov 2002
- 11
January 4th, 2003 12:48 AM #1baket mas maingay and mas ma-vibrate ang diesel engine compared
sa gasoline engine?
January 4th, 2003 12:49 AM #2
kundi po ako nagkakamali, dahil po sa mas mataas na compression ratio ng diesel engines compared sa gasoline engines.
Signature
January 4th, 2003 12:59 AM #3
Yup, it's due the high compression which results to very high pressure that is needed to ignite the diesel fuel.
January 4th, 2003 01:01 AM #4
A gasoline engine compresses at a ratio of 8:1 to 12:1, while a diesel engine compresses at a ratio of 14:1 to as high as 25:1.
January 4th, 2003 01:02 AM #5
Also, diesel fuel has a higher energy density than gasoline. On average, 1 gallon (3.8 L) of diesel fuel contains approximately 155x106 joules (147,000 BTU), while 1 gallon of gasoline contains 132x106 joules (125,000 BTU).
January 4th, 2003 01:09 AM #6
gestapo, di ba ang joules/BTU is unit of energy? hindi ata density. pasensya na kung mali ako, baka nangangalawang na utak ko sa physics/thermodynamics.
Signature
January 4th, 2003 01:16 AM #7
oo nga. unit of energy yung joules/BTU. sa pagkakaintindi ko, (sori po kung mali ako. bata lang po ako. :mrgreen
masmalakas ang energy na na-e-exert ng diesel fuel kaysa sa gas.
January 4th, 2003 01:22 AM #8
And from the way diesel works, it is around 30% more efficient than gasoline engines.
January 4th, 2003 01:26 AM #9
And diesel fuel is more environment friendly to produce.
- Nov 2002
- 11
January 4th, 2003 01:29 AM #10compression ratio lang ba talga?i mean...bat yng ibang gas fed engine kahit high compression considering same displacement e mas tahimik? F1 engines perhaps...LOL
Tesla Philippines
