Hi All,
Nabasa ko lang sa isang comment sa Yahoo! Nagcomment sya dun sa balita na Filipino Bride sa US na nasunog sa loob ng Limo. Gusto ko kasi sana iverify kung totoo yung comment nya, and I guess here is the right place, since marami ditong experts. Here is what the comment said,
"This is really very sad, I almost experience this situation in my car, Just want to share to everyone, I don't want to name the brand of my car since most of the new model cars are having the same system specially the cars with Fuel Injection system. Most of these fuel injection system cars that are having Fuel Pump motors submerged inside the fuel tank are dangerous.
How does it work:
1. The submersible pump is build with sealed type motor that works to pump the fuel from your tank then distribute to your injection system, it work simultaneously whenever you turn your key to ON position and start the ignition.
2. The sealded type submersible pump motor, are normally subjected to worn out and sometimes they are replace with alternative replacement or even sometime original parts.
3. This submersible motor pump sometimes if not properly check and maintain they cause fire due to the pump is powered by 12VDC,and when the submersible motor pump is malfunction, let say the brush inside this motor is worn out and the moror will not run or wont turn its armature, there will be heat generated from this malfuction motor and when the heat comes to extreme, this will cause explosion from your fuel tank, this is because it ignites the fuel inside your fuel tank.
This is an experience that I observed when my well conditioned car suddenly stopped, then I tried to re-start it wont start anymore, through my trouble shooting experience, I finally come to indentify the submersible motor pump that does not work but when I'm trying to remove it I felt extreme heat from this device, I then consulted a very experience electro/mechanic and he says, "Your lucky to find out the problem or else you will surely cook alive inside you car" Thanks God it din't happen... BE CAREFULL guys."
Totoo po kaya to?
