Results 61 to 66 of 66
- Aug 2009
- 137
July 27th, 2010 11:09 AM #61
- Aug 2004
- 163
July 29th, 2010 09:58 PM #62If I may try to rectify some more:
E10 is a BLEND of ethanol and gasoline. It this sense, blending is a physical combination resulting in a solution or a homogenous mixture.
There is no chemical reaction between ethanol and gasoline required to make E10.
Biodiesel is not "precisely" a BLEND.
It is made through a chemical reaction involving a base, alcohol (methanol or ethanol) and a fatty acid.
Biodiesel is an ester resulting from a CHEMICAL REACTION (not just blending or physical combination ) between a fatty acid (i.e. from vegetable oil) and an alcohol.
If you mix biodiesel with petroleum derived diesel fuel, then you have a BLEND (a simple physical combination/mixture)
Note: an ester is a class of organic compound having the general formula R-COO-R'.
The R-CO part comes from the fatty acid while the O-R' portion is from the alcohol.
R' = methyl if one used methanol. R' =ethyl if one used ethanol
P.S. I love it when people talk chemistry!
July 31st, 2010 12:15 AM #63
Dear eric:
Thank you for your post.
It helps to clear up a lot of general misunderstanding regarding fuel chemistry.
The real problem we have now is the use of food-sourced raw materials as the basis of bio-fuels.
I have no problems with the use of materials like waste cooking or vegetable oils, or those derived from the wastes of the food-processing industry - like rendered animal fats etc or those derived from other non-food bio-sources.
The real problem is when wealthy countries turn their farm produce into fuel, reducing the available supplies and thereby creating shortages and increasing the price.
Coupled with the efforts of speculators and hoarders it creates a situation that is most unfair and difficult for the under-developed and poor countries.
Perhaps when the 2nd generation of bio-fuels arrive, (those derived from non-food sources), we will have a genuine and humane alternative to fossil fuels.
Personally, I myself believe that alcohol is best DRUNK, not burnt.
Best Regards,
Dusky Lim
July 31st, 2010 12:44 AM #64
MODERATOR's NOTE:
* Dusky & Eric
Quit the pissing contest or I will have to send both of you to your rooms without dinner.
- Aug 2004
- 163
July 31st, 2010 12:18 PM #65
I agree Dusky .... let's wait for cellulose derived biofuel....the technology appears to be maturing... ethanol, etc from non food plant sources.
GH : Thanks for the warning... no intent to compete here.....just thought a little clarification might help...
my apologies if it sounded otherwise.
- Apr 2009
- 1,902
September 9th, 2010 12:54 PM #66Just last night at the parking lot, fuel started fuming out when I started my carb-fed engine. I found the rubber hose supplying fuel to the carb is dripping, leaking gas bigtime. It's got big cracks already. I had them replaced at once (buti may nadaan pa kong bukas ng auto supply at 10 pm).
Now I know the biggest possible culprit. I'll watch out for the other rubber hoses where gasoline flows.
