Page 53 of 119 FirstFirst ... 34349505152535455565763103 ... LastLast
Results 521 to 530 of 1184
    Feb 2019
    #521
    Quote Originally Posted by JapanABC View Post
    Guys found out something worrying about Baldwin filters' filtration efficiency in the USA's domestic market.
    Attachment 36877
    So VIC oil filter provide much better efficiency than baldwin? at more than half the price.
    #522
    Quote Originally Posted by maculet View Post
    Then sa WIX filter na lang mura pa. May Itatanong din ako regarding sa fuel filter, How good yung fuel filter ni JS Asakashi sobrang mura kasi nasa P375 lang para sa gas type compare sa 2k ng toyota.
    lets wait for those more knowledgeable to chime in. but from heresay kasi sabi indonesian or thai brand ata yun js asakashi pero decent naman. ive also used their fuel and oil filters for a time na. seem ok naman.
    #523
    Attachment 36877
    What was the basis for such claims? Any comparison test made, single pass/multi-pass efficiency? Please provide link.
    USDM truckers are dominated by Baldwin, Cummins Fleetguard, Cat, Donaldson, Parker might as well compare them. Wix, Fram, Purolator, etc were originally intended for small cars.
    May 2017
    #524
    JS Asakashi is definitely a japanese brand same as Vic you can easily find its website, may be made in indonesia or thailand. May be your referring to Sakura filter by ADR Group of Companies in Indonesia.
    #525
    ah yeah sakura pareho kasi puti ang canister. thanks for putting me straight
    #526
    It really depends on how bad of a quality the fake oil filters are, there are times na lalabas kagad symptoms like oil leaking from the bad quality oil filter from its rubber gasket, other symptoms are exploding oil filters which is worse since either the filter could not take extreme pressure, others might take years to know the extent of the damage when you're going to overhaul an engine na, since bad filters will not filter out the contaminants from your engine and those contaminants will the ones that will be damaging your engine parts like piston, piston ring, cylinder liner, con rod bearing & other parts that are being lubricated by the contaminated engine oil, always remember kahit anong ganda pa ng engine oil mo once paired with a bad filter the engine oil will not perform as it says it could perform since the engine oil will be mixing with dust, ashes & other contaminants. Also take note AIR and FUEL filters are as important as the oil filter dahil once contaminants passes through the air and fuel filter it will still contaminate the engine and the engine oil, running an engine with a good filter and good oil will not do you any good if you use a cheap China generic or private label/brand or K&N & other racing filters since in the end you'll end up getting the same contaminants in the engine and in the engine oil every time your engine sucks air/oxygen through the bad air filter and dirty fuel from the bad fuel filters.
    Proof that K&N and other racing filters are bad at filtration and are just plain hype, please watch the link below from Youtube:
    Which Car Air Filter is Best? Let's find out! Fram, K&N, Wix, Purolator, & AC Delco showdown - YouTube
    Finally someone who agrees with me re: K&N air filters. I've been saying that for years. The way they achieve more flow is to have a lot less efficient filtration. They try to argue it's only within a percent or so, but over a few thousand kms run that's gonna be a lot of contaminants sandpapering your engine.
    Dec 2013
    #527
    Actually JS Asakashi is a Japanese brand which in order to compete with the other brands sends their materials from Japan to South Korea to assemble the whole filters to make the costs lower yet maintaining their material quality. Sakura and JS Asakashi are completely different with one another they have no business with each other. Some of the WIX USA filters are also painted in white color, also the previous Purolator for the Asian market was also white in color. Sakura wasn't the 1st one to use white paint on spin-on filters.
    Dec 2013
    #528
    Yes yet people in order to save a few bucks then to buy the washable filters which are actually not good at filtering contaminants.
    You can watch the actual video of the contaminants passing through the K&N filters compared with the other brands, also K&N was shown to have the worst filtration even when compared to a China generic filter.
    Search in youtube:
    "Which Car Air Filter is Best? Let's find out! Fram, K&N, Wix, Purolator, & AC Delco showdown" - Title
    "www.youtube.com/watch?v=sJ3L-E-ufYo&fbclid=IwAR1M2SlR-D8Qo-QAcY5cHmkNThJ79y-9vv9bT0aC3F14Y_kW_zQGYwBiJIc"
    Dec 2013
    #529
    This is the link for the source which I saw the reviews on Baldwin.
    1 Best Oil Filters (June. 22) - Buyer's Guide and Reviews
    Dec 2013
    #530
    Sorry but I think you misunderstood and are comparing apples with oranges.
    VIC was tested 87% filtration for 40 Microns of contaminants(Size of dirt particles) for 5 minutes and after 10 minutes VIC filtration dropped by 6% from 87% to 81% for the 40 microns size of contaminants.
    Baldwin was tested 85.44% filtration for 12~30 Microns of contaminants(Size of dirt particles)
    VIC's testing was using 40 microns which is 10-28 microns or 43~75% bigger than Baldwin's average 10~30 microns. VIC was only tested for 10 minutes which is very alarming since it dropped 6% immediately based from the tests.
    What you need to compare is VIC's 10, 20 & 30 Micron filtration rating with Baldwin in order to get the most accurate comparison:
    VIC testing 30 microns: 71% and 10 microns: 4% at 5 minutes
    VIC testing 30 microns: 68% and 10 microns: 4% at 10 minutes
    Baldwin testing 12~30 microns: 85.44% unknown duration of test
Best Oil/Fuel Filters
