Page 21 of 39 FirstFirst ... 1117181920212223242531 ... LastLast
Results 201 to 210 of 381
    #201
    CTEK is the more aggressive brand right now though when I was in Seattle, I’ve seen a lot using Deltran. Sayang hindi ako nakabili hehe. But if you can afford CTEK, this will be a good buy [emoji1362]
    Deltran is a trusted American brand that's seen everywhere there....even at every local Home Depot. No autovolt, US only sells 110v. CTEK, swede, isn't as visible there.
    #202
    would you know how many amps the charger was pushing in?
    Typically 6Amps on 100Ah truck bat and around 4-5Amps on 45Ah sedan bat, initial current draw would depend on how drained and the internal resistance of the battery.
    Mar 2018
    #203
    Yes panay 110v yun available kaya hindi ako nakabili. Though may nagsabi may autovolt na daw but we haven’t found one. Not meant perhaps hehe
    #204
    what bro 12 vdc said doc
    Sep 2006
    #205
    Now I'm torn, should I buy a smart battery charger or a portable charger/jump starter/powerbank.? My concern is being able to start the car if my battery died down on me somewhere inconvenient or in the middle of the night.
    A smart charger would let me plug in and charge my battery using a wall outlet (hopefully available) and wait for some time to get my battery enough juice to start the car. However, A portable jump starter would start the car conveniently, as long as I regularly charge it and make sure it has enough juice to do its job. Tama ba intindi ko?
    #206
    noted, po.
    #207
    tama po.
    but i am confident, you can afford both. heh heh.
    either product, has limitations on use.
    buying both, and those limitations diminish.
    may i recommend,
    the charger stay in the car or at home. always bring the powerbank in the car. many parking spaces have no access to a mains receptacle.
    if your car is MT... how confident are you at push-starting?
    it needs no powerbank or charger.
    #208
    A smart charger, battery tester(those that read CCA and internal resistance), and onboard volt meter should keep your peace of mind. A jump-starter kit is as good as the health of its internal battery, i'd rather bring jumper cable battery-less thing to worry.
    #209
    is the powerbank useful, if the battery plates have deteriorated to next-to-dead?
    not the charge content, but the ability to hold charge.
    #210
    Yes, doc...if the internal batt of the powerbank is good & has charge.
    Jumper cables, not all are worthy. Some are all insulation....tried 1 that did not even work....& you need to pair w/ another batt. Luck needed for those trips that see a lot of lonely backroads.
Smart Car Battery Charger
