Results 11 to 20 of 30
- Mar 2014
- 901
August 4th, 2014 10:55 AM #11Honda City 1st Gen ride ko po. Same issue with the old battery. Nai-start naman po. Ang concern ko lang, may pagkakataon minsan na ayaw magredondo at click lang marinig sa pagpihit ng susi sa start. Kaya minsan sa pagpihit ng susi sa start, kapag hindi umandar sa 1st try, makaka-ilan attempt pa ako sa pag-start minsan. Palitin na po kaya ang stater?
- Mar 2014
- 901
August 4th, 2014 10:57 AM #12Honda City 1st Gen ride ko po. Same issue with the old battery. Nai-start naman po. Ang concern ko lang, may pagkakataon minsan na ayaw magredondo at click lang marinig sa pagpihit ng susi sa start. Kaya minsan sa pagpihit ng susi sa start, kapag hindi umandar sa 1st try, makaka-ilan attempt pa ako sa pag-start minsan. Palitin na po kaya ang stater?
- Mar 2014
- 901
August 4th, 2014 11:11 AM #14Honda City 1st Gen ride ko po. My concern is the starting issue even with a new battery. same issue encountered with the old battery which made me decide of changing the battery. Same type and brand. Ang sitwasyon ay ganito, minsan pag-start hindi mag-redondo at click lang marinig,pero trying to attempt several times, kapag rumedondo i-start naman. Minsan 1 attempt lang to start, minsan several attempts pa para sya umandar. Kaya ko sir na ask kung palitin na ang starter ko.
- Mar 2014
- 901
August 4th, 2014 11:57 AM #16
Check your battery terminals. Ive experienced that before. Yours might need to be replace already due to corrosion
Posted via Tsikot Mobile App
- Mar 2010
- 2,270
August 5th, 2014 03:43 PM #17
- Jul 2014
- 162
August 5th, 2014 07:03 PM #18Contact lang po ng solenoid starter ang problema Baka pudpud na o madumi na..
Tsikot Mobile App
- 53,883
August 5th, 2014 07:37 PM #19
- Mar 2014
- 901
August 8th, 2014 10:39 PM #20Thanks for your feedback guys. To Flipo, mrjeff and dr._d. I will try your suggestions. And other members had posted as well.
Today, after a day of drive. What i notice is everytime i hold the key a little longer in start position, about a 1 or 2 seconds it will crank and run the starter motor. Anyone know where a competent shop or auto electrician can recommend here in Valenzuela area.
