Results 11 to 17 of 17
- Aug 2006
- 98
January 27th, 2014 09:06 PM #11
- Nov 2009
- 3,503
January 27th, 2014 11:36 PM #12Flourescent ba o incandescent ang dome lamp mo? Try mo isara ang pinto while starting.
Again, its Normal.. Not unless you already checked the items mentioned. O baka fuel related yan like spark plugs, HT wires, coil pack, carb, etc.. We can guess all day giving false diagnosis, but you're the only one who can tell if you start working with the isolation method.
- 53,883
January 28th, 2014 01:28 AM #13my lights also dim when i start my car. and i assure you, there's nothing wrong with my charging system nor my new battery. and it's been doing this for years now..
btw, why did you buy a "reduction starter"?Last edited by dr. d; January 28th, 2014 at 01:30 AM.
- 53,883
January 28th, 2014 08:57 AM #15
baka sir kaya nag dim headlights kasi matagal naka redondo para umi-start... so bumababa reserve capacity ng battery mo..
it would be a good idea sir to fix the hard starting issue kasi it will put a strain on your battery...
again normal lang mag dim dash lights during cranking
- Oct 2009
- 2,271
January 28th, 2014 01:49 PM #16grounding kit lang katapat nyan.kulang sa ground..
minsan pag start mo.click lang tapos start mo ulit saka tutuloy.
he he..
January 28th, 2014 02:53 PM #17
Very informative ang discussion ng thread nato mga bro, yun din napapansin ko medyo parang nalabo mga ilaw sa loob ng dash nya kapag nag i istart tas medyo delay ng ilang segundo yung redondo pero kapag nag start na sya back to normal naman. sa umaga malamig pa makina kaya siguro parang hard starting pero kapag nag init na e wala naman.
