Results 31 to 40 of 55
- Jul 2004
- 55
January 17th, 2012 10:44 PM #31the warranty of my 2008 optra 1.6LS matic will expire this feb. i am looking for an alternative mechanics to bring it to. the recommendation for mario seems good.
quick question: the battery warning and handbrake lights on the instrument panel keeps on popping (intermittent) on even when i am driving. i am sure that the handbrake is not engaged and my battery is new. what could be the cause? thanks.
Tsikot Member Rank 4
- Jun 2006
- 2,605
January 18th, 2012 07:40 PM #32
- Jul 2004
- 55
January 19th, 2012 08:06 AM #33
- Jul 2004
- 55
March 29th, 2012 09:51 AM #34
- Apr 2012
- 1
April 19th, 2012 06:51 PM #35Sir ok naman c sir mario pero medyo mahal din ang singil nila compared sa normal mechanic...
here is my advice if may problem sa car nyo and need some spare parts try to find a replacement mun like sa fuel pump you can use fp of nissan. if sa AC compressor you can use SANDEN compressor. but if wala makita wala talaga magagawa kung hindi punta kay mario (excelent service and reply agad) or kay mikehunter ( pero d ko cya makontact nung nagkaproblem ako) tapos pag d padin kaya go to casa na para sure...
FYI ung sanden aircompressor is only P3800.
e2 ung quote sakin ni arisluvmie from sulit. http://arisluvmie.**************/
may sarili silang shop... kayo nalang kumontact sa kanya...
"puede po sanden my bracket lng n kelangan 1500, ung sanden 3800, filter 1200, service 1500 with freon total 8000"
Hope nakatulong ako sa mga chev optra user...
- Mar 2011
- 7
- Jun 2011
- 251
April 24th, 2012 08:34 PM #37naku na miss cguro namin call nyo sir anyway marami din po kasi kami talgang gawa ngayon ksi bukod sa optra we also specialized sa mga mitshu cars, like itlog,singkit,pizza,fb,4d56,4m40 etc.
may mga bibitaw kasi sa subic this kaya busy kami sa pag gagawa nung mga oto nila.
cencya na kung di kayo agad ma entertain,
anyway amy parts kami ng optra,
may compressor din radiator lahat ng cooling system kasi buong oto yung babaklasin namin contact me for more details kung anong parts ang gusto nyo
09277555272
- Mar 2009
- 100
May 14th, 2012 06:07 PM #38*jetaime91
the sanden compressors at 3800 are converted. it is not the original compressor advisable for the optras.
kaya you need the conversion bracket likewise, etc...
- Oct 2005
- 15
May 20th, 2012 11:42 AM #39Location of Mario's new shop is in this sulit . com . ph ad
www. sulit . com .ph/index.php/view+classifieds/id/5574049/Chevrolet+GM+Ford+Hyundai+Auto+Shop
July 24th, 2012 01:49 AM #40
I had Mario replace my Optra 1.6LS' motor oil, air filter, fuel filter, valve cover gasket, spark plugs, park light bulb, fog light bulb and high tension wires. His mechanic is ok. I suggest that you look over as well if he's not there because his mechanic has a tendency to screw back the part covers etc.
I plan on having my AC compressor changed by him as well. He can source for you OEM parts as well. His original compressor quote was cheaper than Thunder.
Tesla Philippines
