Results 31 to 40 of 151
- Feb 2017
- 37
July 7th, 2018 10:15 AM #31
July 7th, 2018 03:43 PM #32
- Feb 2017
- 37
July 7th, 2018 04:40 PM #33StockEngine. It's amazing mate that it took all these poundings with more than half of it's core is gone. Glad He was able to bust it early, one more reason to inspect under-chassis regularly.
July 7th, 2018 04:49 PM #34
- Feb 2017
- 37
July 21st, 2018 05:21 AM #36
July 21st, 2018 12:03 PM #37
- Feb 2017
- 37
July 22nd, 2018 03:09 AM #38Lol Sorry dude reversed the info, was kinda clumsy when I have pasted the part numbers.
Not really sure, never changed them but fat as day one. Check the pads first, if your complain is the sponginess of the brake then it's normal in the TB. Lots of manufacturers aim for this design, yeah it's not a defect or something, due to wrong chair adjustment by inexperienced drivers especially with long legs, a slight hit in the brake pedal won't cause you to get rear ended. It's not that far though, but it won't bite with a simple touch.
July 28th, 2018 01:31 AM #39
July 28th, 2018 04:20 AM #40
CE-5W40LTR-DX2 ENGINE OIL MINERAL
19348771 Oil Filter
12636838 inl o ring seal Oil Filter
VP-M60 BRAKE CLEANER
52046262 pollen filter
vp-ix50 brake paste
52046262 / E-0645(k&n) air filter
52100212 fuel filter
24585348 / 24582056 drive belt tensioner
24581174 / 24581173 drive belt
12581701 drive belt pulley idler1
94722019 drive belt pulley idler2
94722018 drive belt pulley idler3
12645126 water pump
12643564 rubber plug
93165408Tbrake fluid
94407708 front drive shaft bearing
94258820 front wheel bearing inner
98036594 front wheel bearing hub cap
94227044 front wheel bearing outer
98036595 front wheel bearing seal
94770229 front brake pad
85034685 rear brake pad
frt axle oil(75w90)
rr axle oil (75w90)
12625215/ 12642668 timing belt
12664510 / 12625560 timing belt tensioner
Tesla Philippines
