Page 4 of 16 FirstFirst 1234567814 ... LastLast
Results 31 to 40 of 151
    Feb 2017
    #31
    Quote Originally Posted by kiwileader88 View Post
    Hello all,
    Can somebody confirm that these parts are correct.
    Trailblazer Chevrolet 2015 LTZ SE.
    Thanks a lot.
    Pulley Idler. GM# 94722018
    12605492
    Pulley Timing Belt Idler GM# 12581701
    Bearing Tensioner GM# 12625560
    Belt Timing GM# 12625215
    Drive belt 6PK2871 (Gates Micto-V K061130) 13/16" x 113 5/8" OC
    Tensioner Auto GM# 24585348
    Water pump GM# 12645126
    Check with Thunder Banawe mate or the CASA to be perfectly sure about it.
    I have only the timing belt and drive belt for now.
    Timing Belt: GM#24581173
    Drive Belt: GM#12642668
    the photo depicts how bad the 2 rubbing parts when the shock absorber bushing is gone.
    2000kg kerb w [emoji848]
    Feb 2017
    #33
    StockEngine. It's amazing mate that it took all these poundings with more than half of it's core is gone. Glad He was able to bust it early, one more reason to inspect under-chassis regularly.
    Quote Originally Posted by shadyanderson09 View Post
    yes bro, any "tok"sound needs inspection&repairs
    Feb 2017
    #35
    True mate.
    Apr 2015
    #36
    Thanks for sharing, BTW the correct details below
    Drive Belt: GM#24581173
    Timing Belt:GM#12642668
    Anybody know the part number for the REAR brake pads?
    Thank you.
    #37
    Thank you.
    IIRC, the make that i used to replace my oem brake pads is bendix.
    just brought the sample to my suking auto shop when i bought it.
    Feb 2017
    #38
    Thank you.
    Lol Sorry dude reversed the info, was kinda clumsy when I have pasted the part numbers.
    Not really sure, never changed them but fat as day one. Check the pads first, if your complain is the sponginess of the brake then it's normal in the TB. Lots of manufacturers aim for this design, yeah it's not a defect or something, due to wrong chair adjustment by inexperienced drivers especially with long legs, a slight hit in the brake pedal won't cause you to get rear ended. It's not that far though, but it won't bite with a simple touch.
    Apr 2015
    #39
    Hello,
    Thank you for the info shadyanderson09.
    Here are the part numbers that I have with all shared from this forum.
    Please let me know if I missed something.
    Thank you all.
    Apr 2015
    #40
    Hello,
    Thank you all.
    CE-5W40LTR-DX2 ENGINE OIL MINERAL
    19348771 Oil Filter
    12636838 inl o ring seal Oil Filter
    VP-M60 BRAKE CLEANER
    52046262 pollen filter
    vp-ix50 brake paste
    52046262 / E-0645(k&n) air filter
    52100212 fuel filter
    24585348 / 24582056 drive belt tensioner
    24581174 / 24581173 drive belt
    12581701 drive belt pulley idler1
    94722019 drive belt pulley idler2
    94722018 drive belt pulley idler3
    12645126 water pump
    12643564 rubber plug
    93165408Tbrake fluid
    94407708 front drive shaft bearing
    94258820 front wheel bearing inner
    98036594 front wheel bearing hub cap
    94227044 front wheel bearing outer
    98036595 front wheel bearing seal
    94770229 front brake pad
    85034685 rear brake pad
    frt axle oil(75w90)
    rr axle oil (75w90)
    12625215/ 12642668 timing belt
    12664510 / 12625560 timing belt tensioner
Chevrolet Trailblazer Maintenance...
