Results 461 to 470 of 1357
- Dec 2007
- 186
February 16th, 2014 11:21 AM #461
aside from engine design, consumers may not have realized that it is the ecu that determines fuel efficiency. that is where the fuelling calibration data are stored and fortunately for informed buyers, the 2014 TBZ is equipped with one of the latest hardware/software available in the market.
- Feb 2014
- 9
February 18th, 2014 05:06 PM #462sir n5,pwedeng gawa kayo ng separate thread for 2014 chevy trailblazer 4x4 AT?
- Feb 2014
- 2
February 20th, 2014 10:59 AM #464
Good day to fellow members! Does anyone know if the TB engine uses a timing belt or timing chain?
- Mar 2013
- 40
February 20th, 2014 06:22 PM #465
- Jun 2009
- 222
February 21st, 2014 01:29 AM #466Wow
You can only do that fuel efficiency comparison using fuel tank level sa mga jeepney na regular shape ang mga fuel tank (box shape) and using graduated stick na sinundot sa tank.
Sa modern cars its terrible way of comparing the efficiency using fuel gauge/level indicator.
Una irregular ang shape ng tank as it has to fit into some limited space under the car.
Float sensor is only good in sensing the change in level not the actual volume.
Volume is area x height. Kung malapad ang tank malaki ang area and lesser height for the same volume.
Sorry but its wrong to compare the volume (consumption) based only sa change of height (level). Need also to know first how fuel level sensor/sender works.
- Mar 2009
- 823
February 21st, 2014 01:38 AM #467Both have same volume capacity tank.
Fyi, Gas and diesel tank are also subcontracted hence OEM parts rebranded as genuine
Eg. mitsu parts on an evrest (as posted in another thread complete with photo)
Further more the test made only gives you an idea but you don't need to rely on it, take it with a grain of salt since it's not a hundred percent full proof and all of us knows it save you
Enough of this milage topic I'm sensing a pattern of narrow mindednessLast edited by victorevolution; February 21st, 2014 at 01:42 AM.
- Jun 2009
- 222
February 21st, 2014 01:54 AM #468
February 22nd, 2014 10:11 AM #469
Sir numbah5 inquire lang po dp for TB 4×4&4×2 sa chev makati planning to get one. Thank u paps.
Posted via Tsikot Mobile App
February 23rd, 2014 09:56 AM #470
Pwede ba palagyan ng 4x4 rims yung 4x2 bago ilabas sa casa? How much kaya.
And also kakasya kaya yung tahoe or suburban rims sa TB?
