Results 81 to 90 of 385
February 2nd, 2018 01:20 PM #81
So i had it right pala. [emoji3]
I wasn't really sure because i was a bit preoccupied while the vid was playing. Hehe
Anyway, if your unit will hold up the test of unpredictable local road conditions then this find of yours is really a good buy bro
when you look into the abyss, the abyss looks into you
February 2nd, 2018 01:55 PM #82
Advantage and disadvantage between internal and external sensors? Sa accuracy?
February 2nd, 2018 02:05 PM #83
Same lang bro.- pero, I like iyong internal (in my case- OEM) better...
Matrabaho lang kapag nagpalit ng baterya... tanggal ang goma, kasi nasa pito... Anyway, every 3 years siguro...
At tyre rotation,- parang iikot din ang orientation - haven't done it yet.... Sa akin okay lang,- basta may sumingaw,- check lahat ng gulong....
Iyong external,- as I said earlier,- takaw nakaw... magnanakaw, kolektor o iyong nawalan ng kapareho....
- Dec 2007
- 727
February 2nd, 2018 02:15 PM #84It'll pay for itself though we won't feel it because it's kinda preventive maintenance ang dating. 2011 I was suppose to buy a set na kaso it costs P6k. After I few months I ended up driving with a flat tire. The tire costs P5k so I'm effect, if I bought the TPMS prior to that incident, bawi na. Immediately after that incident bumili na ako. Onwards hindi na nangyari because you get to check the tire pressure everytime you drive.
Sent from my ASUS_Z012D using Tapatalk
- May 2015
- 40
February 2nd, 2018 07:00 PM #85here are the things i considered 2.5 years ago when deciding which sensor to buy.
internal sensor advantages
- di mananakaw unless nakawin buong tire
- no need to remove the sensor during top up ng air
internal sensor disadvantages
- mahal, around 2k+ ang price difference nya for steelmate brand when i bought my tpms
- disposable sensors since hermetically sealed sya it's not possible to replace the batt but batt life is 5 years.
- DIY installation not possible
- needs wheel balancing upon installation
- hassle sa tire rotation kasi kelangan ideflate ang tire para malipat yong sensors
external sensor advantages
- mas mura of course
- easy DIY installation in 10 mins
- replaceable battery and has 3 years batt life as per manual
- no wheel balancing needed kasi magaan lang sya
- easy replacement when sensor get defective
- posibleng manakaw. i don't consider it madaling manakaw kasi without the right tool masisira mo yong sensor bago matanggal
sa accuracy same lang sila +/- 1 psi. those are the things i considered kaya i ended up buying external sensors. i don't know kung true pa ba lahat yan, didn't do any research anymore after buying it. baka malaki na improvement ngayon ng internal sensor
February 2nd, 2018 09:35 PM #86
- Aug 2012
- 2,767
February 2nd, 2018 09:50 PM #87
February 6th, 2018 05:22 PM #88
^ so kapag external ang sensors, mas convenient sya kapag nag rotate ng gulong kasi mas madali sya i-set kumpara sa internal ones, that is if tire placement specific ang mga sensors nito
February 6th, 2018 08:37 PM #89
February 17th, 2018 10:33 PM #90
Tesla Philippines
