Page 33 of 39 FirstFirst ... 23293031323334353637 ... LastLast
Results 321 to 330 of 385
    May 2010
    #321
    Next time, apply a little silicone spray around the valve stem prior to screwing on the lock-nut and sensor.
    I actually used silicone grease. The lock nut also got stuck on the external sensor housing and not the valve stem.
    May pag-xenomorph yata tong aso namin, masyado acidic ang wiwi haha
    Aug 2017
    #322
    Mga sirs, good day. Saan kaya nakakabili nung nut na lock sa external sensors? Nawala kasi yung sa isang gulong ko. Thanks [emoji16]
    Sent from my LYA-L29 using Tsikot Forums mobile app
    #323
    Quote Originally Posted by gvalquisola View Post
    if malapit ka sa pasig, bigyan kita 4 pcs [emoji28]
    im not using mine
    Sent from my Redmi Note 9 Pro using Tapatalk
    Jun 2005
    #324
    Autosupply dami. Pati sa bolt&nut stores meron
    Sent from my MI MAX 2 using Tapatalk
    Aug 2017
    #325
    Quote Originally Posted by sirkosero View Post
    Naikot ko na autosupply stores samin sir pati hardware, wala sila [emoji28] thanks po sa reply
    Aug 2017
    #326
    im not using mine
    Sayang sir, from cavite pa ako. Worry ko lang kasi baka machempuhan at mapagtripan yung isang sensor ko. [emoji28]
    Salamat po sa offer sir
    Jun 2005
    #327
    Yung tread size lang naman important dyan. Baka pati yung kapal hanap mo. Yun mahihirapan ka talaga bumili. Pero yung tread, meron yan.
    #328
    pag nagawi ka nalang dito, or lalamove mo?
    Aug 2017
    #329
    Check ko muna sir sa wilcon baka maka score ako nung nut. I'll message you nalang kapag kunin ko yung iyo. Baka ipalalamove ko nalang [emoji16] maraming salamat po!
    Jul 2006
    #330
    dun sa mga naka internal sensors, nagpa wheel-balance pa ba kayo after the installation?
TPMS (Tire Pressure Monitoring System)
