Results 201 to 210 of 385
March 2nd, 2019 02:04 PM #201
I made the mistake of tightening the lock nuts too much , i eventually had to seek help loosening them lest i damage the tire valves. [emoji23]
That's why for me, i won't readily discount the efficacy of that darned nut.
do what you gotta do so you can do what you wanna doLast edited by baludoy; March 2nd, 2019 at 02:06 PM.
- Mar 2017
- 143
March 14th, 2019 04:50 PM #202so parang valve cap lang yung sensor part ng TPMS, may extra na provided ba? or may nabibili na separate valve cap lang ng TPMS?
Thinking ahead kasi ilang beses na din ako nakuhanan ng valve cap
March 14th, 2019 04:59 PM #203
- Oct 2012
- 4,851
March 15th, 2019 04:58 AM #204
- May 2007
- 106
March 23rd, 2019 01:50 PM #205Question po sa mga naka Zeepin Solar Powered TPMS, yung internal battery po ba ng base/receiver unit napapalitan kapag hindi na nag charge thru solar panels assuming the panels are still working? If napapalitan ano po size ng battery ng base/receiver unit?
March 23rd, 2019 08:16 PM #206
Kahit na kunin niya yung sensor useless naman kung wala siya nung monitor. Unless na lang trip niya lang nakawin. Though masikip pa din ung lock nut nung sa akin.
Previously before i installed a TPMS, naka plain black valve cap lang ako. Hindi pag iinteresan ng mga kolokoy.
April 5th, 2019 07:18 PM #207
Perfection.... the reading on my tires while parked in a hot basement for 4 days while I attended a training abroad.
I recently got this for my Innova, a Zeepin C260 TPMS for under P2k. It's totally wireless (with optional USB charging) and uses a built-in solar panel to recharge the internal battery.
The pressure readings agrees with my AccuTire MS-4021B digital pressure gauge to within half a PSI. I purposely bought the external-type sensor version because it affords the most flexibility when doing things like rotating the tires, transfering the sensor to the spare tire, or changing the sensor batteries.
The receiver automatically turns on when it senses vibration and shuts off 3 minutes after it stops sensing movement.
April 5th, 2019 11:58 PM #208
May 29th, 2019 09:47 AM #209
Driving to work, I was startled by alarm beeps. It was my TPMS. Turned out, a nasty nail tried to hitch a ride.
I know TPMS is important but I've only considered that in theory. But today, I've experienced first hand how helpful it actually is.
May 29th, 2019 10:03 AM #210
It pays for itself na, bro....
Had a similar experience too, in an unfamiliar place, where I had to go back to the vehicle near midnight, and drive end to end of MM, to fetch our kid from a party....
Gave me the opportunity to had the tyre replaced immediately, when I still had the time... 6PM on a Saturday....
