Page 4 of 39 FirstFirst 1234567814 ... LastLast
Results 31 to 40 of 385
    #31
    Try checking other China brand. Mas mahal ang Steelmate by almost double sa ibang brand na parehas ang features niya. Nauna lang and steelmate sa business na alarm and sensor kaya mas kilala sila at mas mahal.
    Jun 2015
    #32
    Sir any recommendations who sells tpms and installs them? Makati / Pasay area
    May 2015
    #33
    Quote Originally Posted by acmech View Post
    in case you are interested i am selling this TP-70 DIY TPMS for P4500
    Click image for larger version.
    #34
    questions on the external sensors:
    1. do you have to remove them entirely when adding air to your tire?
    2. do you just twist it in when installing? does this mean that the "pito" will be continuously pressed while it is installed? di kaya masira ang pito core in the long run?
    TIA
    May 2015
    #35
    Quote Originally Posted by coiter View Post
    TIA
    1. yes. but since namomonitor ko na ang pressure realtime di pa ako nagpahangin since i installed it 3 months ago.
    2. threaded sya and just like installing a valve cap may lock nut lang sya para di madaling manakaw. yes pressed ang pito while installed and i am not sure kung masisira nga sya spring lang naman yong stressed. but who cares if masira ang pito it just cost P50
    Jun 2015
    #36
    Hi Guys,
    For those looking for an aftermarket TPMS, we have new stocks for Steelmate models including DIY and Professionally installed TPMS.
    Models available:
    TP-74 DIY TPMS w/ Cig plug display - 7,490
    TP-71I Professional TPMS w/ Cig plug display - 7,990
    TP-10I Professional TPMS w/ LCD Display - 7,990
    TP-05 Professional TPMS for Head Unit installation (good for vehicles with head unit/ DVD installed) - 8,490
    For more details you can check
    Safecar Electronics PH
    Automotive Parts & Accessories – Safecar Electronics
    Thanks!
    Nov 2015
    #37
    Quote Originally Posted by ndauto View Post
    Hi Guys,
    Models available:
    Thanks!
    Would like to place an order for TP-05 including shipping/freight charges bound for Davao City.
    Payment will be processed thru BDO, already PM'ed on FB but still awaiting for reply.
    Thanks and best regards.
    Feb 2016
    #38
    Hi,
    Has anyone tried connecting the TP-05 to Growl Audio's head unit? I'm thinking of getting the TP-05 but I'm not sure how it will work with my HU. Also, how will it actually work? I read you need to press the TPMS button, but would you need to navigate through the HU menu to get to the readings? Or does it automatically trigger the application to launch just like the backup camera when the car is put on reverse?
    Thanks!
    #39
    ok SAna nga iyong mga aftermarket tpms sensors na powered by our vehicle's lighter plug units.
    ang problema ko lang dito kasi baka ngatngatin ng aso namin at medyo crowded na iyong lighter adaptor ko w/ the dashcam and the thermometer/voltmeter plugged into it
    #40
    bro, you have a pic of your tpms? thanks.
TPMS (Tire Pressure Monitoring System)
