Results 61 to 70 of 89
April 30th, 2018 08:38 AM #61
i still have the one baludoy is using (red with only voltage display) and the vst one (both with voltage and temperature displays and isang usb charging port). halos pareho ng reading pag pinagpapalit-palit ko. mas mabagal lang refresh rate nung vst and mababa lang yung amperes coming out of the usb port.
- Aug 2019
- 97
August 22nd, 2019 01:12 PM #62puwede po bang mag add nang battery for back up or e parallel nalang ba.
August 22nd, 2019 01:42 PM #63
- 53,883
August 23rd, 2019 10:55 AM #65
Kapag battery,- theoretically,- unlimited power....
Ang rating ng battery refers to capacity - measured in Ampere-Hours.... So, a 40 A-Hr battery can theoretically deliver, limited by its material/physical construction: 1A for 40 hours or 20A in 2 hours, etc
And during its normal operation,- it is the alternator which is delivering the power, regulated/supported by the battery
Bro- I do not see a need for a backup... It's like having a backup gasoline tank,- when the OEM is more than enough...
Afraid of not being able to start a vehicle? Jumper cables or replace the battery when its warranty period expires for peace of mind...
- Apr 2010
- 130
August 23rd, 2019 09:00 PM #66Or bili ka ng portable car battery jump starter. Mas mura sa ibang bansa magpabili.
For checking battery, I use VST voltmeter, multimeter, or Ancel BA101 battery tester - minsan nagsale sa Lazada. I saw some casa and battery shops using the same type of tester. Medyo praning lang yung result na REPLACE sa tester, so I just continue using the car battery until the first sign na di na maka-start ng engine. Of course with my backup battery car jump starter always in the car. Huwag lang ilagay sa mainit na lugar.
Sulit din bili ko sa multitester, I was able to have one battery under warranty replaced when I showed the REPLACE result. When they checked with their tester, replace din yung result.
August 26th, 2019 08:29 AM #68
- May 2016
- 14
August 26th, 2019 11:40 AM #69
August 26th, 2019 11:55 AM #70
Tesla Philippines
