Results 651 to 660 of 3510
June 4th, 2015 10:59 PM #651
Thanks a lot sir! That's nice and clean setup you got there. I'm now set on buying a non-wifi SJ4000. Just having second thoughts if having it as a permanent dash cam has its cons. But with the inputs here I think that won't be a big issue. Will check tomorrow kung pwede ko din kabit sa rear view mirror stalk. Kapag doable baka di na din ako bumili ng suction.
- Jan 2008
- 4,726
June 4th, 2015 11:02 PM #652
- Jan 2015
- 149
June 5th, 2015 11:33 AM #653Repost form another thread: Interesting free android app I downloaded and used recently on my roadtrip. CamOnRoad, it makes use of your phone camera as a virtual Dashcam while overlayed with Map direction from Google map. Very good feature and resolution will depend on your Phone camera. There was one drawback through, My phone frequently overheats due to sunlight exposure on the winshield and constant charging. Looking to relocate the phone on the aircon vent next time once i get a mount for that. Otherwise its quite a good app. Have anyone tried this?
June 5th, 2015 12:06 PM #654
June 5th, 2015 01:56 PM #655
June 5th, 2015 02:01 PM #656
Another method of using the accessories provided in the box to install the SJCAM, instead of buying that suction cap, is by using that flatform piece (w/ the 3M adhesive) and fix it atop of your headunit or dashboard. This is good kasi, if you would, mas madali ang pag-tanggal-kabit..
- Jan 2008
- 4,726
June 5th, 2015 02:56 PM #657
June 5th, 2015 03:31 PM #658
What i meant is:
This can't be:
12v ---> SJCAM
Because it should be:
12v ---> 5/6V Adaptor ---> SJCAM
June 5th, 2015 05:02 PM #659
Yep, that's exactly what I did. I used the charger that came with the SJCAM mount, including its 12V to 5V head. Then this was attached to a fuse, afterwards attached directly to the ACC.
It has exactly the same functionality as with plugging it to the cigarette lighter slot, except it's much much cleaner looking.
Tesla Philippines
