Page 189 of 351 FirstFirst ... 89139179185186187188189190191192193199239289 ... LastLast
Results 1,881 to 1,890 of 3510
    #1881
    Quote Originally Posted by ParticleX View Post
    Marami branches ang Qube, meron 2 within the vicinity of Gilmore. Have you called the branch before going in? Yun ang isa pang gusto ko sa X-Cam, may storefront and warranty claims should be easier.
    I believe they accept shipping but haven't tried it, check their website
    I contacted their head office through their FB page. Out of stock daw and earliest possible delivery is end of July but not sure yet.
    may optional GPS logger and speed display yata yung A7. mukhang maganda add on ito.
    Meron din GPS logger bro yung 0805. Mas discrete pa kasi mas maliit.
    Quote Originally Posted by wewoy_romero View Post
    i gave up and used suction cup on the windshield. since naka-medium tints naman ako, hindi halata. hindi talaga pwede sa rear view mirror ng gen1 crv eh.
    Between suction and adhesive, mas matibay naman siguro yung adhesive 'no? Hindi ko naman tatanggalin or lilipat sa ibang kotse so ok lang na permanent.
    Aug 2005
    #1882
    Suction hindi matibay and over time mahuhulog din yung unit mo because of the windshield heat lalo na kung bilad sa araw. I use adhesive mount of the Qube A7 on both my vehicles. It is mounted just at the back of the rearview mirror.
    Click image for larger version.
    Jun 2012
    #1883
    Quote Originally Posted by leinahtan View Post
    Oo nga. Ang pangit ng suction. Mahulig pa camera baka masira
    Meron ba dito nakahanap ng adhesive mount para sa trnascend drivepro? Nagtanong tanong ako. 600 ang isang adehesive mount. Ang mahal
    Aug 2005
    #1884
    Walang stock ng Xcam A7! [emoji30]
    And then yung mga Mini 0805 na nasa Lazada, all of them are imported, so I don't know if the products are really available, and if I will be able to return/replace the product in case it's defective. The only local supplier of the Mini 0805 doesn't have stock either.
    To A7 and 0805 users, hope you can help point me to suppliers with stocks. Thanks!
    I bought my Qube A7 (2 sets) from their Solenad 3, Sta. Rosa branch. Actually it's just a showroom. I went there personally and ordered 1 after the other of the dashcam. Tip: If you chose to power up the A7 dashcam directly from the lighter port, suggest you install a kill switch.
    Aug 2005
    #1885
    Quote Originally Posted by dct View Post
    May workaround dyan kung gusto mo ng suction or wala kang mahanap na adhesive mount. Para hindi mahulog yung unit with the suction cup, using the 3m mounting tape, cut strips of it (about 5mm wide). Careful not to touch the exposed adhesive part of the tape. Stick the strips around the edges of the suction cup, the part of which that will touch the windscreen surface. Confirm the placement by marking the area with masking tape. Kung masaya ka na sa placement, peel off the the 3m tape and carefully mount the suction cup.
    Jun 2012
    #1886
    Di ko gets sir. May picture ka ba? Hehe
    Aug 2005
    #1887
    nadikit ko na sa dash noon pero tinanggal ko. Well for the sake of helping each other out gumawa ulit ako for showy he he.Click image for larger version.
    Jun 2012
    #1888
    Stable ba to sir? Kasi magkakaroon ng spacing e
    Jun 2012
    #1889
    Pag tinanggal kasi yung screw ng mount, ganyan mangyari, meron kayang something universal adhesive mount na magshoot dyan? From action cam, etc..
    Aug 2005
    #1890
    In my experience it is stable. I used this method on my wife's garmin gps. She's been always complaining of the suction cup fall out but nung nilagyan ko ng mounting tape tahimik na sya, he he. Imagine mas mabigat ang gps device as against the lighter dashcams. Mas matibay lalo sya kung lahat ng surface ng suction cup is covered with the tape.
Blackbox DVR/Dashcam
