Results 11 to 20 of 25
- Mar 2010
- 301
July 30th, 2015 05:28 PM #2[QUOTE=garyq;2578194]plug and play LEDs = waste of money.[/QUO
Hi. Sir Garyg ask ko lang, kapag magpapakabit ka ng LED Bulb, kailan ng Projector headlights? May Sariling shop po kayo?
- Mar 2010
- 301
March 16th, 2015 10:55 PM #3
March 17th, 2015 12:45 AM #4
May plug and play na led hl. Yung iba naman may kunti lang na modification. Ask mo lang pagbibilhan mo if plug and play.
Fasten your seatbelt! Or else...Driven To Thrill!
- Apr 2010
- 740
April 7th, 2015 08:21 PM #5Napundi yung low nung isang piraso ng Narva 100/90w after 1.5yrs, pinalit ko new pair same model din (Narva 48901). According sa isang site, 150hrs lang ang lifespan nito.
Sa Ace bili ko dati 250/pc, sa auto supply 160/pc lang same markings
April 7th, 2015 10:31 PM #6150hrs lang ang lifespan nito
- May 2015
- 4
May 10th, 2015 06:55 PM #8
i've tried both philips extreme vision and osram NB. konti lang difference sa oem. the best pa din talaga sa akin ang raybrig. yung H7 na dalawa ko (on GS and sorento) 55w rated but 130w ang buga, more light, longer beam. you can also get it in many temps (3700k, 4400k, 5000k, 6000k). around P1600 per pair last na bili ko for the sorento when the hid ballast conked out. halos same color sila ng HID. na-compare ko kasi yung driver's side head light e naka hid pa din, passenger side head light hid lang ang pundido ang ballast. mas malayo pa ang buga kesa sa hid so i will probably just disconnect the hid on the driver's side when i get home next time and replace it with the other raybrig bulb.
May 10th, 2015 09:56 PM #10
di ko pa na-try h4 ng raybrig e. last month ibabalik ko sana to h4 yung bt50 headlights ko kaso iba na yung mount nung hid upgrade, d2r/s/c na yung mount. buti na lang di pa ko nakabili ng bulbs. wala din kasi ako makita na h4. puro h7, h11 and hb4 lang nakita ko so far. di ko lang alam sa banawe baka meron.
Tesla Philippines
