Results 201 to 210 of 1387
August 27th, 2017 12:26 AM #201
Yan ang problema, safety mo lang iniisip mo. how about other motorist?
No hindi ako seller and I'm not planning to. I just make sure that I personally know kung anong mods sinasalpak ko sa vehicle ko not because it is written on the label.
Please paki screen shot kung saan ko sinabi na hindi nakakasilaw ang high beam? I never said that. Ang sabi ko pakitaan mo ako ng pics ng naka properly retrofitted na headlight na may glare. yun lang. Controlled output pinag uusapan bossing. Pag nag wall shot ka ng cut-off ng healight mo dapat walang glare o light above the cutoff. dyan pa alng maikita mo na if may glare o wala. Try mo mag wall shot at 25ft. And oh since we are one the topic, wala ako makitang "step" sa mga cut off dun sa page na yun. I'm sure familiar ka sa term na "step" ng cut off dahil even halogen ay meron nyan.
Boss naka screen shot sa akin ang nag post sa page sa na sinasabi mo. Yung post nya ang caption is "Fogs only H11" tingnan mo dun sa page and tingnan mo rin ang output. Meron pa isa dun naka low pero check mo ang ilaw sa gilid abot hanggang taas ng pader.Last edited by D3nb3r; August 27th, 2017 at 12:51 AM.
August 27th, 2017 03:09 AM #202
*glenn manikis - heres a comparison proper cut-off with step on the left And your so called led on the right at di ko alam kung saan kinuha ang HID kit dyan sa comparison but that is not a proper HID+projector combo. Both HID and led sa 1st pic on the right ay walang mga step ang cut off.
And please explain to me this 2nd pic on the left is from the fb page you mentioned. Really? fogs/low beam? Now check out the right side of the photo of a low beam on a properly retrofitted HL.
Di sa sinisiraan ko ang seller. I know he or she is just trying to make a living. Ang sa akin lang pag nag claim tayo be sure that we could back it up lalo na pag nag compare kana ng products mo sa ibang products.
Again di ako seller. Just an enthusiast/student of automotive lighting.
Sent from my SM-J710GN using TapatalkLast edited by D3nb3r; August 27th, 2017 at 03:15 AM.
August 27th, 2017 09:33 AM #203
Maganda talaga ang cut off... compare mo sa bowl like headlights.. na walang cut off.... pero whats important is... hindi glaring and malakas ang output... and you can see clearly whats in front of you...
Ang ganda nga ng cut off- ang
Pangit naman ng price.... its much more expensive than KS led that can give you a better output...
pero pag naka HID ka na at pinalitan mo ng bulb lang ng KS LED maganda na din ang CUT OFF... mas malakas pa... pero at a fraction of the cost.
Post pics.. that are actual shot/pictures taken by the customers not by the seller...
Pics at Ks led are shots taken by customers on their phone... no filter, no special camera...
You can also read some post there that some were former HID retrofit users.. are now more satistified when they switch to KS led... tapos Its Way cheaper pa.... and wont damage your lens..
Cge paps.. need to work na.. kahit sun. Kasi madami tau kausap... sakin lang share ko lang sainyo experience ko... may pambile din naman ako ng HID retrofit kahit hangang likod pa ng sasakyan lagyan ko... pero sayang naman ang pera kung meron ibang option na mura na mas malakas pa... and a 14 month warranty..
August 27th, 2017 10:42 AM #204
that is waht I've been saying all along.
pano nyo na sabi na mas malakas? May output shot kayo with lux meter? and at what distance nilagay ang measuring tool? I can post a pic again of TRS and lightwerkz of how they test their items with data and numbers and the test was done in a controlled space para balance ang lahat ng test.
- Oct 2009
- 152
August 28th, 2017 11:20 AM #205Hmm, I also considered buying those PnP LED kits before but after reading about the topic i decided on the HID retrofit route. I noticed that a lot are selling Philips Luxeon, etc.. but the only thing Philips with these products are the LEDs itself. The circuit board and more importantly the design are all just individual, untested designs by the seller. I looked at reviews and output shots of these kits and these ranged from really bad output with glare to a little better looking than Halogen. On some reflectors it would work, on some it would not. Looks like the idea that it has a lot more usable brightness is due to the color which is a lot whiter than Halogens and a lot more contrast. For me, I think these are risky and I would have needed to to try out different sets and combinations, and the benefit would not have been too much. I would rather have used the high end Osram and Philips Halogens for about 2k.
By the way Philips has an original X-treme Ultinon for H4 sized bulb replacement. The reviews seem to be decent but its being sold for 220 usd.
August 28th, 2017 01:14 PM #206
Trust me, any bulb that is installed on any housing that is not specifically designed for that bulb will never work properly. Kaya ang mga reputable brands, oem man or aftermarket ay gumagawa ng mga replacement bulbs that is made specifically for a certain housing.
I also want to point out that whiter light (north of 6000K) ay useless sa adverse weather, ulan man or fog. lalo na sa asphalt road. That is why if you compare ang mga HID bulbs like Osram NB(4200k) has better contrast if compare mo sa Osram CBI(5500K) during adverse weather condition. Heck even rally cars use 3000k and below for fog lights na almost yellow na during night competition. But whiter light has more bling effect on it and also if mostly city driving people usually prefer the cbi vs nb. But I'm a philips guy so naka 85122 ako dati and I plan to install XV sa plan DIY retrofit ko
Ultinon is 6000k I would'nt use that if I were you if palagi kang out of town. But hey, as long as di nasisilaw ang ibang motorist(in-coming or travelling in same direction as you) at gusto mo ng bling look then go for it.
- Oct 2009
- 152
August 28th, 2017 03:36 PM #207
August 28th, 2017 07:19 PM #208
August 28th, 2017 07:47 PM #209
Waiting for my osram cbi's to arrive. Iniisip ko kung bili pa ako ng 'branded' na ballast kung would it help the output more eh. Im using NHK ballast right now.
And is it true nakakasunog ng plastic lens ng headlight pag nag-55 watts na system na?
August 28th, 2017 08:20 PM #210
NHK ballast ay ok naman po. Even lightwekz shop sa US is using them though pag dating sa internal circuitry mas advance ang brands like morimoto dahil pag may na detect na hindi tama yung morimoto ballast ay mag shutdown siya to prevent damage sa ibang components.
Wala pa ata akong nabasa or nakita na may nasunog na headlight lens(plastic) ang 55w if it was properly installed. At ang 55w system ay ang ballast ang 55w not the bulb, dis-advantage ng 55w ballast though malakas talaga ang output nya ay iiksi ang lifespan ng bulb dahil over driven na ang bulb. Kaya nga sa redline pag nag request ka ng 55w ballast ay 1yr lang ata warranty instead of the normal 2yrs if i'm not mistaken.
Tesla Philippines
