Results 1 to 10 of 717
January 10th, 2011 06:35 PM #1
New generation of the two most acclaimed and compaired Headlight bulbs....
Has anyone used any of the two?
I called one of the shops I know regarding the Philips Xtreme vision....and they said that the stocks will be coming in by the end of the month....Last edited by locoroco777; January 10th, 2011 at 06:45 PM.
February 15th, 2011 10:06 PM #3
Up ko lang yung question.. saang shop makakabili ng Philips x-treme and how much po?
- Dec 2007
- 37
February 16th, 2011 02:52 PM #4
- Dec 2009
- 89
February 17th, 2011 09:45 AM #5alin ang mas malakas = osram all weather/philips xp 55/65 watts o ordinary na 90/100watts?
- Dec 2007
- 37
February 18th, 2011 02:10 PM #6*aeo62000,
technically mas malakas ang 90/100w bulb. Pero subjective kasi ang pagiging "mas malakas" na headlight. Eto ang pros and cons sa mga choices mo:
Osram All Seasons:
Pros:
A little Yellowish light, meaning more contrast pag bad weather.
Malakas.
Comes in 55/60w+30% more light, meron ring 80/100w.
Cons:
Hindi lahat gusto ng yellowish light.
Higher wattage (80/100w) means upgraded wiring is recommended.
Mid Priced (approx 400-500php per piece)
Philips XP:
Pros:
stock wattage with +80% more light.
no mods needed.
well-focused.
Cons:
Shorter Lifespan compared to normal bulbs.
Expensive (1.4k to 2.3k php per pair)r
Lighting may not be bright compared to Hi-wattage bulbs (subjective).
Normal 90/100w Bulbs:
Pros:
Generally Bright
Cheap (other brands are sold around 200php per piece)
Durable (if you stick with known brands)
Cons:
Needs upgraded wiring to be more effective.
May damage plastic lenses.
Not recommended by OEM.
Please take note that lighting is very subjective. It's best to try out different bulbs on your own car and see what's best for you.
- Dec 2007
- 37
February 24th, 2011 12:46 PM #8Sir harold13, the NB's are considered one of the best bulbs, along with XP's, due to their power and focus while using stock wattage.
- Jan 2008
- 70
February 25th, 2011 10:49 AM #9Anyone here know where i can buy either of the two next-gen bulbs? May nakita ako kahapon sa Jet Aldo Car Accessories, 1.7k daw for X-treme Vision H7. Meron ba fakes nun? Prefer ko sana NB Plus pero wala ako mahanap. help! thanks!
February 25th, 2011 11:08 AM #10
try mo dun sa abonifacio corner C3 tabi ng caltex yung specialty store talaga ng mga bombilya....pang bahay man o kahit san...
