Results 11 to 20 of 107
April 23rd, 2018 01:36 PM #11
Yung led bulbs mo ba na ikakabit ay direct replacement ng stock bulbs mo, or is it designed specifically for your headlight housing? If not then regardless if huhulihin ka or not glare sa on-coming traffic lang yan kahit naka low beam kana. Bago ka mag palit ng bulb, try to mark your HL output sa flat wall para may basehan ka pag adjust mo sa output ng ipapalit mong bulb. Dyan pa lang makikita mo na if may glare or wala.
If its properly installed then wala kang dapat problemahin. If di pwede ang led then lahat ng mga totl variant ng mga car manufacturer ay hindi na pwede sa daan pati ang mga motorcycles like honda RS150 or even the ducati panigale ay huhulihin na rin dahil led ang headlights.
Pina ka paboritong sitahin sa kalsada ng mga authorities ay yung mga sasakyan that looks like a christmas tree sa dami ng color ng headlights.
- Apr 2018
- 46
April 26th, 2018 12:45 AM #12
April 26th, 2018 01:01 AM #13
Kung mag led ka, make sure na yung headlight mo ay projector at hindi reflector.
Kung reflector yan 100% sure ako may glare yan.
Pag inadjust mo naman pababa headlight mo, yung visibility mo naman ang affected.
Nag upgrade din ako sa led na reflector yung housing ko, bukod sa kalat yung buga nasisilaw pa mga kasalubong.
I upgraded to hid na with projector lens, cost me 14k. with angel eyes for drl.
When I initially converted to led, I spent 10k including the fog light.
If I only planned it right at the start, nakatipid sana ako ng 7k.
If you really want to go led, i-upgrade mo din headlight mo to projector.
Sa lazada may binebenta na mga led projectors. Dilang ako sure sa quality.
Before ako nag led nag try din ako ng Philips halogen, di inabot ng 4 months.
April 26th, 2018 09:22 AM #14
- 53,883
April 26th, 2018 10:16 AM #15hindi puedeng siguro lang. dapat sigurado.
i hope you can lower it enough, as to be truly non-glare-ing to the oncoming motorist.
it is very easy to test it naman.
simply stand in front of your car a good distance away, lower your head to the appropriate level, and see if you get blinded.
April 26th, 2018 11:34 AM #16
Meron naman pong nabibili na led bulbs that is a direct replacement ng halogen bulbs from osram or philips pero ang price is so expensive that it would be practical na magpa hid retrofit ka nalang with a lot sharper and better output performance. I wouldnt recommend yung mga sa lazada na AES projectors. IMO yung stock bulbs would've better performance kesa dun if I'm not mistaken.
Pag meron naka sunod sa akin minsan na ganyan and walang paki sa akin, pauunahin ko yung sasakyan na yan tapos susundan ko sandali at flick ko yung high ko. Since naka aftermarket hid projector and bulbs na ako, mararanasan nya din ano ang feeling na masilaw ng headlight na mas maliwanag pa kesa sa kanya. My wife tells me na if I do this thing, I'm no better than that guy na walang pake sa ibang motorista. She's actually right.
April 26th, 2018 02:30 PM #17
Parang awa mo na wag ka na dumagdag pa sa daming nakakasilaw sa gabi na motorista. Pag me kasalubong tuloy ako feeling ko kinukuha na ko ng liwanag.
- Nov 2017
- 1,748
April 27th, 2018 02:39 PM #18
- Apr 2018
- 46
April 28th, 2018 01:01 AM #19
