Results 451 to 460 of 2382
January 24th, 2014 07:39 PM #1
To rephrase my question: How many inches should the fog light cutoff be from the head light cutoff and at which specific distance from the wall? Thanks.
EDIT: I know that head light/fog light aiming is a complicated issue (lamp axis height, etc.) and I'm probably oversimplifying it. But I was hoping you could give me a rough and general idea. Failing that, I just might go back to you for a fog light retrofit. Haha.
Sent from my Galaxy NoteLast edited by Pipefish; January 24th, 2014 at 08:26 PM.
January 24th, 2014 08:54 PM #2
OK, here's a more intelligent question: How many inches below the fog light axis/center should the cutoff be at 25 feet? 2 inches? 2.5 inches? 3 inches? What do you normally use? Thanks.
January 25th, 2014 03:29 PM #3
same way you adjust the HL. 25ft away on flat surface, measure from ground to middle ng fogs, project to the wall and this is your cutoff height. But with your stock fogs you can only approximate this.
January 25th, 2014 04:12 PM #4
Thanks, Gary. So no need to measure 1.5"-4" below the center of the fog light? Anyway, napapagod na 'ko mag-DIY. I managed to convert the projector from my stock head lights, after your retrofit, by sealing the holes. I have a nice cutoff (and the projector is big, maybe about 2.5") but the projector is not stable. I have a feeling pag nalubak ako uurong siya. Haha.
January 25th, 2014 04:37 PM #5
Gary, 'yung fog light retrofit mo ba kasing-sharp ang cutoff ng sa head lights? At gaano katagal gawin? May stages din ba 'to (1-3) o isa lang? Kasing-liwanag ba ng H1 mo 'yung D2S Stage 3 ng head lights ko at same color? Thanks.
January 27th, 2014 11:33 PM #6
Pwede ba natin Gawin ganyan kalakas yung linagay nating camaro style drl sa trailblazer ko?
February 25th, 2014 02:27 AM #7
Pwede ba natin Gawin ganyan kalakas yung camaro style angel eyes ko sir Gary? How much aabutin kasama yang led eyeline? And what can we do sa tail lights?
February 25th, 2014 01:05 PM #8
- Feb 2014
- 112
February 26th, 2014 04:45 PM #10Sir Garyq, pwede po ba yan sa old cars like my Honda City '97? atleast may konting angas din oto ko kahit sa HL lng. ^_^
