Page 38 of 239 FirstFirst ... 283435363738394041424888138 ... LastLast
Results 371 to 380 of 2382
    Dec 2002
    #371
    vrl: pwede bro and mukhang your hl needs restoration na rin. sent you a PM
    #372
    Sir gary what about LEDs for the turn signal lamps, brake or park light, and reverse light sa tail lights? Gumagawa rin po ba kayo?
    If yes, pa-send naman po kung how much. TIA
    Up ko lang po question ko.
    Pa send na rin po ng quote sa 3rd brake lights (08 Vios and 96 Civic EK). Thanks po sir!
    #373
    *sir gary
    pano kaya mounting nong DRL sa ride ko?
    Dec 2002
    #374
    junkun: suggestion ko sa loob ng fog lights mo para Porsche style na DRL. I can retrofit 3 OEM leds sa loob nung fogs and wire it as a DRL. Ganda nyan
    chikselog: bro I suggest getting plug in LEDs for these. I have T10s and 7443 bulbs na LED.
    installed my aftermarket (bolt on) projectors sa dalawang Civic before ako mag break and eto results.
    LO
    HI
    To explain a bit about this setup. I have worked with many types of "bolt on" projectors and to tell you frankly, bolt ons are not really bolt ons if you want to do it correctly. Many of these projectors need some modifications to correct mounting and also to maximize output. One might say na ok naman as is, pero sa akin, nabuksan mo na rin lang, bakit di mo pa ayusin and mount it properly and get the max output from the projectors. I have also tried and tested many "bolt on" projectors and the one I am using now has the best output in terms of width and intensity. I modify these projectors to get the best output and mount it properly sa headlight. The harness and the sealant for this setup is also the same as my oem package so everything in the setup is designed for long term use.
    May 2010
    #375
    Quote Originally Posted by garyq View Post
    denki: pwede para Euro dating, sa fogs mo pwede mag retro nyan or HID projector for your fogs! hehehe.
    haha tignan na lang naten sa january.. yung projector.. next time na yun.. hahaha
    #376
    Ampogi nung headlights nung EG ! How much yung bolt-ons, bro ? Hehehe.
    #377
    may sample pic ka ba sir?
    Dec 2002
    #378
    renzo: ganyan pala gusto mo denji yan na lumang model, I dunno kung meron pa ganyan na headlamps ngayon. PM na lang kita
    junkun: tatlong oem LEDs na diamond formation inside your existing fogs, ganun itsura nun. diko makita yung FD na ginawa ko. mga present Porsche naka ganun na DRL, search mo sa net.
    #379
    Pero iilaw parin bulbs sa fogs? Try ko search sa google
    #380
    Bumagay kasi sa body bro. Smoked headlamps tapos amber corners.
    Pa-PM bro nung price ng projectors ha, para pag may budget at nasimulan ko ulit 'tong corolla. tia.
HID Projector Retrofits by garyq
