Page 191 of 239 FirstFirst ... 91141181187188189190191192193194195201 ... LastLast
Results 1,901 to 1,910 of 2382
    Mar 2012
    #1901
    Quote Originally Posted by rwesley View Post
    Actually clear lens lang sya hinde ko na pinakulayan baka makaapekto lang sa visibility ng HL, white color ang AE at naka tap sya sa park light switch para may switch pa rin sya if i wish na off ang AE, i will post the night output soon.....
    what i mean po sa painted shields is yung shield nang projector behind the bulbs and not the lens po. i dont think it will affect the visibility dahil yung makikita natin na color sa lens is reflection lang of the painted shield dun sa projector. but anyway, that is just me so bale yung park light nyo po is same switch as the angel eyes?
    Dec 2002
    #1902
    No the shields are not painted and I wala naman reason to paint it. also the angel eyes are tap to the park light.
    guys: sent you PM
    #1903
    Quote Originally Posted by garyq View Post
    guys: sent you PM
    sir gary thanks sa retrofit.... hinde ko pa naadjust, mababa pa ang mounting ng low beam, just a little bit adjustment lang naman.
    Dec 2002
    #1904
    ok just use the stock screws for up/down adjustment. 25ft away from the wall, mga 36" height nyan or less
    Accent Stage3
    Optional LED DRL
    Tried to go as close to the OEM type na headlights with projectors and OEM naman dumating.
    #1905
    ^ sir gary, eto na yung light bar para sa accent? kaya ba yung ganitong style?:
    https://www.facebook.com/photo.php?f...type=1&theater
    Dec 2002
    #1906
    170: pwede. see also exledshop.com as we re-sell for them and also install
    Dec 2002
    #1907
    peugeot 3008 fog lamp retrofit.
    OEM look and function.
    you can see here the output of the stock halogen HEADMLAMPS (left picture) vs. the FOG retrofit (right picture).
    The output of the fogs is more intense and wider than the stock halogen HL. This setup will at least double your lighting output.
    Nov 2012
    #1908
    Hi Gary, here are some pics of the issue I had earlier today.
    Dec 2002
    #1909
    Sked mo lang na madaan sa shop. a 50% moist coverage on the HL is acceptable as per oem specs provided nawawala pag uminit coz sometimes pag very humid at nababad, the cold air inside cant vent out. Problem yung pag nag tubig and pag ganun meron leak talaga. SMS me sa 0908 8183545. Pwede bukas.
    Nov 2012
    #1910
    Ok, sent u a messg already
HID Projector Retrofits by garyq
