Page 206 of 239 FirstFirst ... 106156196202203204205206207208209210216 ... LastLast
Results 2,051 to 2,060 of 2382
    Dec 2002
    #2051
    Hyundai Elantra/Avante MD 2014
    OEM package
    Aug 2005
    #2052
    Hi Gary, saw your projects and i'm interested. Can you pm me the price and the specs of the stage 1, 2 and 3 retrofit for the 2014 Montero? Tia
    Sent from my iPhone using Tsikot Forums
    Dec 2002
    #2053
    gabo: sent you a PM
    Vehicle specific DRL/fog light assembly for Hyundai Accent 2012-13. Dual intensity output for DRL function and parklight/driving light function. Complete with auto module and wiring harness
    Aug 2012
    #2054
    Quote Originally Posted by garyq View Post
    gabo: sent you a PM
    Huwat, no projector lens? Mortal sin. Hehe. Gary, question: for fog light throw (HID projector), how many inches should it be lower than the normal head light cut off? OK lang rin ba kung kapantay lang ng head lights? Thanks.
    Aug 2012
    #2055
    To rephrase my question: How many inches should the fog light cutoff be from the head light cutoff and at which specific distance from the wall? Thanks.
    EDIT: I know that head light/fog light aiming is a complicated issue (lamp axis height, etc.) and I'm probably oversimplifying it. But I was hoping you could give me a rough and general idea. Failing that, I just might go back to you for a fog light retrofit. Haha.
    Sent from my Galaxy Note
    Aug 2012
    #2056
    OK, here's a more intelligent question: How many inches below the fog light axis/center should the cutoff be at 25 feet? 2 inches? 2.5 inches? 3 inches? What do you normally use? Thanks.
    Dec 2002
    #2057
    same way you adjust the HL. 25ft away on flat surface, measure from ground to middle ng fogs, project to the wall and this is your cutoff height. But with your stock fogs you can only approximate this.
    Aug 2012
    #2058
    Thanks, Gary. So no need to measure 1.5"-4" below the center of the fog light? Anyway, napapagod na 'ko mag-DIY. I managed to convert the projector from my stock head lights, after your retrofit, by sealing the holes. I have a nice cutoff (and the projector is big, maybe about 2.5") but the projector is not stable. I have a feeling pag nalubak ako uurong siya. Haha.
    Aug 2012
    #2059
    Gary, 'yung fog light retrofit mo ba kasing-sharp ang cutoff ng sa head lights? At gaano katagal gawin? May stages din ba 'to (1-3) o isa lang? Kasing-liwanag ba ng H1 mo 'yung D2S Stage 3 ng head lights ko at same color? Thanks.
    Dec 2002
    #2060
    yung 70mm yes, very sharp but more important, kasing intense and wide yung output. isang package lang. 4300k din
HID Projector Retrofits by garyq
