Results 1,241 to 1,250 of 1395
- Nov 2016
- 13
November 21st, 2016 06:26 PM #1241Unit: Mitsu Lancer 2001 GLS 1.5cc matic
4g92A Gas
on highway 9L/km
on city 8L/km
November 21st, 2016 09:38 PM #1242
BANNED BANNED BANNED
- Jun 2007
- 122
November 24th, 2016 11:32 AM #1243Madali lang patipirin exp at mga sasakyan na di pa electronic throttle. Punoin mo lang palagi fuel tank tapos before mag 85% refuel ka para above operating range ka ng EVAP. Di masyado effective sa mga bagong sasakyan na palaging naka ON EVAP.
Fuel Emission (Fuel Evaporating) is the biggest factor that increases your fuel consumption. Gasoline initial boiling point is 35°C / 95°F at atmospheric pressure
and 39 °C / 99 °F the fuel tank. Is it not STUPID to put something that generate heat inside the fuel tank? Fuel vapors generated from the gasoline cooled fuel pump is burned at the Catalytic Converter without producing power.
November 24th, 2016 04:16 PM #1244
Galing naman, all the car manufacturers in the world with billions of dollars of R&D couldn't think of that.
Also odd because whether I fill up my Mazda 3 with 3/4 left in the tank or with 1/4 left in the tank, my mileage is still the same at 5-6 km/L for city driving. Hindi naman electronic throttle yun.
You know what improves my FC to 12 km/L? Driving on the highway. [emoji12]
- Jun 2007
- 122
November 28th, 2016 06:56 AM #1245WHAT? They are spending billions on advertising to convince people that their newer model of vehicles are getting more fuel efficient, more safe and more environment friendly even though they're not.
"If you tell a big enough lie and tell it frequently enough, it will be believed."
According to EPA Evaporative emissions occur several ways: https://nepis.epa.gov/Exe/ZyPDF.cgi/...y=P10001KF.PDF
DIURNAL: Gasoline EVAPORATION INCREASES as the TEMPERATURE RISES during the day, HEATING the FUEL TANK and venting gasoline vapors.
RUNNING LOSSES: The hot engine and EXHAUST SYSTEM can vaporize gasoline when the car is running.
HOT SOAK: The ENGINE REMAINS HOT for a period of time after the CAR IS TURNED OFF, and GASOLINE EVAPORATION CONTINUES when the CAR IS PARKED.
REFUELING: Gasoline vapors are always present in fuel tanks. These vapors are forced out when the tank is filled with liquid fuel.
PERMEATION emissions are specific hydrocarbon compounds that escape through micro-pores in pipes, fittings, fuel tanks, and other vehicle components (typically made of PLASTIC or RUBBER). They differ from leaks in that they occur on the molecular level and do not represent a mechanical/material failure in a specific location. https://nepis.epa.gov/Exe/ZyPDF.cgi?Dockey=P100KB5V.pdf
Pano mo compute ang fuel consumption kung di mo alam exact volume ng fuel tapos estimated lang din yung natirang fuel? Matakaw talaga pag within 15-85% fuel level dahil ng EVAP tapos return type fuel system. Pero from full hanggang 85% napakatipid. Mas malakas pa sa gas 2012 CRV ko kesa sa F150 4.2 V6 OHV at E150 na 4.6 V8. Malaki at mabigat pa rim ng CRV (17") kesa sa 98 F150 (16") at E150 (15").
- 53,883
November 28th, 2016 09:04 AM #1246aren't the vapor pressure and rate of evaporation the same, whether the tank is 15% full or 85% full?
November 28th, 2016 01:00 PM #1247
Your post is riddled with inaccuracies and partial-truths. Allow me the pleasure of a rebuttal.
Let's stick to facts and simple physics... Newer vehicles are built with lighter materials, employing tighter engine tolerances, more efficient transmission gearing, and closed-looped, computer-controlled ignition systems that delivers precise fuel and air quantity as required, among many others. Why would you say that newer [internal combustion] cars are NOT more fuel efficient compared to older [internal combustion] vehicles?
Don't get me started on 'safety', as that is a different topic altogether.
Additionally, modern vehicles have a 'closed' fuel system. In fact, while the engine is running, the fuel tank is maintained at a slight negative pressure (vacuum). If there's a leak (ie. faulty EVAP, loose or faulty fuel filler cap, etc.), a vacuum will never happen, tripping a pressure sensor and sending a Check Engine Light to the driver while a DTC is triggered (P 452 EVAP System Pressure Sensor/Switch Low DTC)
- Dec 2013
- 680
- Jun 2007
- 122
December 3rd, 2016 06:47 AM #1249What? Puro naman FICTION mga pinagsasabi mol
Almost everything about EVAP, EGR and Vapor Canister are lies. May vent ang fuel tank. Kaya nag auautomatic shut off yung nozzle ng gas station hindi dahil puno na ang tank kundi dahil naharangan na ng liquid yung vapor vent. Gasoline Volumetric Expansion rate is 4x more greater than water. The Fuel Cap relieves excess pressure (2 PSI)& vacuum build up in the fuel tank. Ano ba tawag mo sa mga magkakatabing pipe na mataas sa gas station?
Permeation is not serious problem if your fuel tank is made of metal. Made of plastic na kaya mga fuel tank ngayon.
- Jun 2007
- 122
December 13th, 2016 03:53 AM #1250
Tesla Philippines
