Results 2,691 to 2,700 of 4196
- 128
September 17th, 2008 05:43 PM #2691Noticed that some refilling stations' lpg are cleaner than others. Check if your station have periodic cleaning schedule. We have noticed clogging (oil residue) injectors specially from stations with underground tanks.
If the injectors are clogged most installers would recommend a change of injectors and these are at least Php5K upwards depending on the brand. Valtek Italy has given us the authority to clean and recalibrate the injectors and this would be part of our warranty service.
Also just concluded conversion on a fleet of trucks to run on Recycled Vegetable Oil if anyone is interested
- Jul 2008
- 102
September 17th, 2008 06:56 PM #2692Hi bigMike how are you? I agree periodic check-ups have to be done to make sure that LPG filled in your car is clear of residue. We do that maintenance here at our station.
On residue going to your Valtek rail, installing a filter before going to the vaporizer plus another filter from vaporizer to your rail should solve some problems from these impurities.
Cheers!
September 18th, 2008 09:10 AM #2693
It seems there is a "small" problem with SGI-LPG systems being sensitive to the cleanliness of the LPG supply. Some Auto-LPG refueling stations seems to pump "contaminated" LPG. The contamination is oil.
Since LPG injectors were designed to flow gaseous LPG so oil (in liquid form) can clog up the injector from flowing properly.
Venturi LPG systems seems to be unaffected by this problem.
LPG stations who regularly clean their tanks are better because this will minimize the oil contamination. Along Shaw, the better stations seems to be CLEANFUEL and TOTAL. Worst offender along Shaw is Petron Shaw.Last edited by ghosthunter; September 18th, 2008 at 09:15 AM.
September 18th, 2008 10:15 AM #2694
So does it mean that the LPG fuel filter is not capable of filtering this kind of contaminant? as such particulate matter only?
- Jul 2008
- 62
September 18th, 2008 10:17 AM #2695is this also normal? amoy lpg sa engine bay lalo na sa side na kung nasaan ang vaporizer. noticeable din ang amoy. mas malakas amoy after a long drive.
on lpg, my tachometer reading is about 800rpm at idle (aircon off) and about 1000rpm with aircon on. ok din lang po ba ito?
- 128
September 18th, 2008 12:43 PM #2696
September 18th, 2008 10:48 PM #2697
parang hinde normal ito, baka may leak better have it check boss. yung sa akin i can see white residue sa vaporizer pero walang amoy, not sure if this is leak. minomonitor ko pa.
about the tachometer reading parang hinde naka adjust ng tama yan, yung sa akin naka set sa 700-800 idle without AC pag naka AC naman di nalalayo, minsan nag ffluctuate yung idle, nag ddrop at 400 pero madali naman bumabalik sa 700 with or without AC. baka airfilter niyo madumi na.
September 19th, 2008 08:55 AM #2698
September 19th, 2008 09:00 AM #2699
September 19th, 2008 09:22 AM #2700
I wonder if this has something to do with sparkplugs wearing out sooner on some Auto-LPG equipped cars?
Side note:
http://www.bosch.com.au/content/language1/html/5673.htm
Check the "Suitable for LPG" note on these set of sparkplugs... do they know something we don't?
.Last edited by ghosthunter; September 19th, 2008 at 09:27 AM.
Tesla Philippines
