Page 6 of 12 FirstFirst ... 2345678910 ... LastLast
Results 51 to 60 of 118
    #51
    guys,
    salamat s mga naibigay nyong info.
    http://journeytoforever.org/biodiesel_make.html>>>>>>>> this site is where i first learned about BD fr WVO last year. this is really good site. kaya ako naglakas loob n gagawa kaso nga hirap maghanap ng materials.
    warm regards
    ifontok
    #52
    pero i asked a friend who was a former management trainee sa mcdo...
    di raw veggie oil gamit nila?!
    Dec 2002
    #53
    veggie yan bro. coconut or palm oil.
    #54
    hmmmm okie. ask ko nga uli sha.
    baka nadistract lang ako sa kakatingin sa kanya. ;)
    #55
    how much na ba ang BD today? malapit na ang registration ko & last year reading ko sa trooper is 1.95... inspite of catalytic converter...
    Aug 2006
    #56
    Hello...i'm also researching the use of veggie oil in diesel engines. i came across a story in the net that a certain Tony Deamer of the Republic of Vanuatu, South Pacific Ocean (a tropical country same as ours) who has been running his diesel vehicles with coconut oil (not biodiesel)...just in case you want to read this article, type "Tony Deamer Vanuatu" and several websites will open for you to select...happy reading.
    Sep 2006
    #57
    hello everyone! My group is currently working on a plant design to manufacture biodiesel from jatropha curcas seeds (tuba-tuba), and we would appreciate any information you might give us..... thanks!!!!!
    Apr 2004
    #58
    sir please check out the "biodiesel rulez" thread. it's the focal thread on biodiesel here.
    #59
    yes it is true you can use used cooking oil in your diesels only if you are using the injection pump types not the crdi daw, have been using it since i have a friend who supplies me 60 liters a week and so far have consumed average of 40 liters a week although it saves you money it just lacks a little power i mean you really can note the less in pull but the car still climbs and pulls just that you will notice a drop in pull. Have used it pure, mixed whatever ratios. Started with 1.5 liters to 4 liters thats when diesel was only at less than 30 thats why it 1.5 liter per bottle per fill up of 100 peso diesel, but recently madmax168 tried hundred percent and it was okay daw so increased ratio sometimes i do run 100 when fuel is low so pour it in until i get to a station, hehehe for those interested tried it on a besta 2.7 , 2c fx, kia pregio, pajero 93 , and a 98 space gear, well so far they are all ok and yup using a high ratio of oil does clean out the carbon cause there is no more sulfur to burn and which creates the foul smell and the big amount of carbon. So it is safe, some would ask how safe okay the fx is still in the 150kms and still original state of injector the besta accumulated severl thousand of kms well used it with oil of 30 % to laoag had injectors repaired since it developed a leak as in it drips diesel so had to have gasket replaced and calibrated cost of 3000pesos the pregio and pajero space gear still in ok condition. But in case any of you guys do intend to filtering the oil is the hardest buy a .1 micron water filter and force it thru however i just juse a 1 micron well the filter in the vans are just 5 microns according to manufacturers specs so i guess its safe but even in 1 microns there will be this brownish liquid like or fine almost ash like particles still so just pour the oil carefully not to include the brown liquid like ash . But then if diesel gets back to below 30 then its not worth it, by the way have talked to mc do have a hard time getting thier oil have not tried jollibee thou
    Jul 2006
    #60
    Guys,
    Try to do a search for Dr. Rico Cruz, he's a Filipino Scientist based in the U.S. He is claiming that he had made a ccatalys that could make biodiesel in about 6 hours by using used cooking oil. Byproducts are diesel and the ones used in making soap.
    His nephew in Leyte (i think) is using it in his diesel engines. This has big potential for the fuel can be made by batching. We can even make it in our own backyards.
    I hope he markets his catalyst here in the Philippines...
    Nawa'y Patnubayan tayo ng MAYKAPAL sa ating paglalakbay.
Alternative Fuel Source: Waste Vegetable Oil (WVO) aka Used Cooking Oil [MERGED]
