Results 31 to 40 of 83
February 10th, 2020 06:38 PM #31
Ayoko damihan choices mas nakaka-lito hehehe
Here at work we use 4x4 only and we used to have other brands like Ford and Mitsubishi.
Now only Toyota remains.
The old Land Cruiser Safari is still working nearly 300k miles while the other brands already retired 8 years ago.
I can always see old model hilux and corollas na fully loaded (the usual scene you see on African movies) plying the unpaved roads of Africa with ease hence I love Toyota hehehe.
Sent from my SM-A505GN using Tapatalk
- Apr 2008
- 6,235
February 10th, 2020 07:57 PM #32The bigger the rim the more expensive the tire! [emoji23] Sa 2010 Carnival namin, I replaced the stock 225/70R16 with 245/70R16. Natuwa ako at hindi na sumasayad ang nguso niya sa mga matatarik na rampa. [emoji28]
Hindi mo ba kailangan ng 4x4? The Hilux 2.4E 4x4 is a good deal, IMHO.
Sent from my SM-G965N using Tapatalk
February 10th, 2020 08:08 PM #33
Mga twice a year lang po aahon sa Mt. Banahaw, the rest city driving na and family car hence Innova or Rush.
Ayoko po pick-up ganyan gamit namin dito work sa Africa kaya alam ko yung tagtag hehehe and nakukulangan ako sa space sa loob lalo na nilagyan na gamit mga bata.
- Apr 2008
- 6,235
February 10th, 2020 08:59 PM #34Mga ganon kataas ang gawan mo. At least pantay na siguro sa Fortuner ang taas niyan.
February 10th, 2020 09:20 PM #35
- Apr 2008
- 6,235
February 10th, 2020 09:36 PM #36
February 10th, 2020 09:44 PM #37
193 sa Crysta in India. Sa ibang website may nakita pa ako 167.
If it is indeed 176mm then it is around 1" lower than Avanza (200mm).
Adding 2" (176 + 50.8 = 226.8mm) will indeed bring it higher than 220mm of Fortuner
February 10th, 2020 09:53 PM #38
- 53,883
February 10th, 2020 10:15 PM #39
- May 2016
- 546
February 11th, 2020 12:01 AM #40Base it on the Fortuner with 225mm, less the difference in tire radius, around 50mm sabi ng tire calculator, and you get 175mm give or take. Both use the same platform and underchassis, so pwede iassume.
These numbers don't mean much. Mas tiwala ako sa Innova with a lower min clearance than a crossover na mas mataas.
Tesla Philippines
