Results 31 to 40 of 72
July 16th, 2023 10:41 AM #31
- Nov 2019
- 1,239
July 16th, 2023 01:10 PM #32Anong unit po ito? At anong car yung mas malakas pa ang AC compare sa unit na yan?
I asked this before kasi and never got an answer pa, if mahina ba talaga AC ng mga smaller displacement engine compare sa higher displacement engines.
Example: Mahina AC ng Xpander compare sa Montero during noontime.
July 16th, 2023 01:20 PM #33
Mahina ang AC ng Ford Territory 1st Gen compared to all our previous cars, mostly Civics. Kahit ung 10 year old Civic ko mas malamig ang buga kahit tirik ang araw. Parang hilaw ang lamig ng Territory and I did a thermometer test 9c lang sagad niya. From babad sa initan, mas mabilis din lumamig ang buga ng old car ko. Ung tipong in a few seconds ramdam mo malamig na ang buga. Sa territory akala mo nakapatay ang compressor, mahigit 3 minutes bago medyo lumamig ang buga.
July 16th, 2023 01:50 PM #34
- Nov 2019
- 1,239
July 16th, 2023 01:54 PM #35So parang related pa rin sa displacement engine.
Not sure ano displacement ng 10 yr old Civic, nasa 1.8 ba yan or 2.0L na?
Baka may makapag compare dito AC ng Xpander vs Territory (puro 1.5L displacement engine to).
Nahihinaan ako sa AC ng Xpander din compare sa Montero.
Baka malakas lang talaga AC ng mga higher displacement engine.
- Nov 2019
- 1,239
July 16th, 2023 01:58 PM #36
July 16th, 2023 02:08 PM #37
1.8 ang Civic ko, we don't use auto climate. Max setting agad pag andar, then hihinaan na lang ang fan later. Pero ang thermostat, hindi inaalia sa 16c, sagad palagi.
- Nov 2019
- 1,239
July 16th, 2023 03:26 PM #38I mean sa Ford Territory nyo po, try nyo disable Auto climate settings.
Then set to desired temperature (16C if eto max settings ng Ford territory).
I am suspecting sa Auto climate feature yan, baka hindi maganda algorithm ng Ford auto climate feature when auto adjusting temperature settings ng AC sa ambient temp inside the car.
Also, if mahina lamig buga na parang hangin lang then malamig lang after ilang minutes, I think expected yan sa auto settings.
Sa unit ko, I set fan to high muna for 2 mins.
Reason is para mabuga lahat amoy kulob if meron man.
Pero depende na sa inyo if during ON, cold agad ang mag activate.
Nawala kasi amoy kulob ng car ko if I set fan to high muna for 2 mins everytime i turned on the unit from cold start.
July 16th, 2023 05:58 PM #39
Hmmm, pwede pala magsabay ang manual at auto climate? I'm not sure of this yet, I'll check sa manual. Pinacheck ko ito sa casa as part of warranty, wala naman silang binanggit na ganun, they just said everything is normal naman including refrigerant level.
- Nov 2019
- 1,239
July 16th, 2023 07:54 PM #40I think sa Ford territory, nasa headunit yung control para ma disable mo Auto settings ng AC.
Sa unit ko, may switch for auto only.
But if I manually switch fan (increase or decrease fan settings), auto is automatically switched off.
Then I can switch temp settings and fan settings manually and it will stay on that settings.
I need to press Auto button to reactivate auto settings.
Also, my car has Auto and Sync feature, since dual climate yung feature ng AC ko.
The front passenger can set his desired settings or press Sync para both passenger and driver has same settings (Auto, temp value, Fan speed).
Tesla Philippines
