Results 11 to 20 of 31
- Sep 2010
- 3,006
June 12th, 2022 07:41 PM #1
June 12th, 2022 08:00 PM #2
I wouldn’t consider a 7-seater on such a small frame, even the same thought on a Mobilio or BRV or XL7. If you want a comfortable 7-seater, maybe consider an Innova or Okavango or Xtrail or diesel CRV.
ToyotaPH priced the RAV4 ridiculously high. Even the top-spec model is only a FWD and priced over 2M with not much to offer against the competition except for its Toyota brand name. You will see more CRVs, Foresters, and CX5s on the road. Since it is not as common, keeping one maybe a challenge later if you need major parts. Usual needed fluids may not be an issue.
- Sep 2010
- 3,006
June 12th, 2022 08:14 PM #3
June 12th, 2022 08:20 PM #4
Get the Forester, better for the family. There are a lot of Foresters on the road. Di naman sirain. Most cars naman Di mahirap yung usual parts - brake pads, suspension bushings, tires, etc. Fluids are also readily available.
I don’t think a car around 5-10 years will need a major part replacement like an engine, turbocharger, transmission, or driveshaft unless the car model has a history of unreliability.
June 13th, 2022 10:06 AM #5
+1 with Egon's recommendation. I'm also shopping around for a 2nd hand Subaru Forester. I plan to use it for my family's car camping trip. The high ground clearance (I think it's 200mm or almosr 8 inch), AWD and excellent visibility are plus factors for me.
I see a lot of 2nd hand Forester offerings at FB marketplace. 500 to 800k seems to be the usual range. The XTs especially the stock ones are getting rare.
BANNED BANNED BANNED
- Sep 2015
- 13,917
June 13th, 2022 01:53 PM #7bugsy,
dagdagan mo pa mag jimny ka. Iyan na tumalo sa porma ng coolray at juke. Or maganda yung hatchback ng honda city na ultimo upuan ng driver pwede iflatten.
Pero naliliitan ako sa gulong ng jimny.
sayang pera sa 750thou tapos bili ka rav4!!!! Ang lakas makatito nyan.
June 13th, 2022 03:09 PM #9
Ground clearance of a Forester or Outback is at 8.7” or 221mm, similar to the usual PPVs. If getting the XT, better look for the 2017-2018 models which comes stock with steering-adaptive headlights. All AWD Subarus come with X-Mode, a system that will have the car maximize traction for off-road surfaces.
Assuming you’re a speed junkie - no PPV or CUV or even most compact cars can hold a candle in terms of performance against the Forester XT. It is quick off a sprint (between 7 to 8 seconds in 0 to 100kmh) and it can get you to over 200kmh assuming you have the nerves to drive that fast. Not to mention it can easily crawl in mud, sand, gravel, or lahar without fear of getting stuck.
Sa mga anti-CVT, di Puwede Subaru or Honda or newer Toyotas. Get something else though don’t settle for those with dinosaur 4-speed ATs.
- Sep 2010
- 3,006
June 13th, 2022 06:14 PM #10
Tesla Philippines
