Page 11 of 13 FirstFirst ... 78910111213 LastLast
Results 101 to 110 of 122
    Feb 2009
    #101
    Hehehe
    There is a difference between flammable and combustible. Flammable liquids burn at very low temperature. Combustible materials burn at around 100 degrees and higher.
    Mar 2012
    #102
    Unless flammable liquid is atomized you cant ignite it. If it is in liquid form, it has to reach its flash point first before you can ignite flammable liquids. Combustible materials ignites depending on its material composition and the heat applied. Combustible materials will also explode if you reduce it into powder like substance pag na expose sa open flame.
    * gh0str1d3r- The usual materials po na gina gamit sa car audio is asphalt, butyl or butyl-rubber(hybrid). Any particular reason why you would want to use a roof insulation? If the reason is budget, then you can buy the acoustipad (asphalt) around P350 ata ang price. easy to install pa. And dont worry your car will not burst into flames mababa nga lang melting point ng asphalt kaysa Butyl based deadeners. Basically, the purpose of deadening our doors is to prevent our door panels from resonating. Just my 2 cents.
    #103
    Quote Originally Posted by D3nb3r View Post
    Yes..for budget reason 😞 tingnan ko sana kung ok. San po nakaka bili ng acoustipad? Eh butyl naman po? Magkano?
    Mar 2012
    #104
    Quote Originally Posted by gh0str1d3r View Post
    Yes..for budget reason �� tingnan ko sana kung ok. San po nakaka bili ng acoustipad? Eh butyl naman po? Magkano?
    halos lahat ng mga reputable audio shops may acoustipad po. Jeff Tan of Araneta Car Accessories is an example. Marami din mga butyl deadeners like, sonus, xsite, lightning lab are few of the brands out there and is around 700-800/sheet. Since budget friendly na deadening yung hanap mo then I guess STP's is out of the equation. HTH.
    Edit: Have you tried back reading this thread? Which ever type of deadener you choose, there will always be a trade-off.
    #105
    May number po kyo no Jeff tan?
    Mar 2012
    #106
    pm mo siya dito
    Mar 2015
    #107
    pwede po kaya yung fiber glasss?
    Mar 2004
    #108
    Bringing this thread back to life. Can you recommend a store that can do this for my subaru legacy wagon? I'm not into sound set ups but I really just want a quiet car. I think the road noise enters my cabin too much. Thanks!
    Resurrecting this topic. Were you able to find a reputable installer for this? Was it effective in reducing NVH?
    Jun 2017
    #109
    ok sir, salamat po.ganun na nga lang siguro gaawin ko bbridge ko yung channels ng amp, tapos yung coax ko sa HU ko nalang di-direcho, baka po kasi yung gusto mangyari ni sir heaven rios pang pro na po at pang malakihan, kaya siguro ganun po yung sinasabi nya sakin na setup. thank you sir ha.
    Aug 2015
    #110
    Hey guys.........
    baka meron jan pwede magbigay ng tips saan mas mura/fair magpa sound deadening. nag inquire ako sa LA Car accesories medyo mahal.. though i know medyo magandang quality din nilalagay nila. Pero baka meron sulit na alternatives jan hehe
Sound Deadening / Deadener Tips
