Page 57 of 307 FirstFirst ... 74753545556575859606167107157 ... LastLast
Results 561 to 570 of 3070
    #561
    ^ wala tweeter pod vios mo? Pacustomized mo na rin yan.
    Aug 2004
    #562
    Better seps pa rin para tumaas ang stage. Pero pagawa ka pa mounts. Ako Targa budget lang eh. Problema mas mahal pa ang customized mounts kesa speakers :hysterical:
    #563
    Wala ako tweeter pod kasi manual pa side mirror ko. :hysterical:
    Sa dashboard kaya?
    Aug 2004
    #564
    Either sa A-pillar yan or nakapatong sa dash. Ang advantage ng nasa gitna ang console walang haharang sa tweeter sa driver side
    #565
    Tamang patong lang sa dashboard yan para at least di mag rattle.
    Aug 2004
    #566
    Pwede rin pasok sa cupholder :hysterical:
    #567
    ^ HAHAHA!
    Sa dashboard na lang. Pero baka magreflect sa windshield mo, nakakairita yun. Haha
    #568
    Ilalagay naman sa corner ng dashboard kaya di na magrereflect yun.
    Jan 2013
    #569
    Good day mga sirs.
    I would like to ask, anyone here have experience using Thunder Audio subwoofers? How'd this compare to Targa or JBL subwoofers?
    Oh, and anybody experienced having seps which lack bass compared to OEM or coaxials? I put in amplified ( amp is 125w * 4ohms) 6.5" Infinity Reference seps in front and I placed my old, flooded and unamplified 6.5" blaupunkts coaxials at the back. I've noticed that the Blaupunkts push more midbass than the Infinity. All doors are dampened and sealed, and I don't have any HPF or LPF running. Ganito ba talaga ito?
    Aug 2010
    #570
    *thread
    Reflection inside the car isn't a problem. It's a standard and given. Just as long as the first reflection doesn't occur 5ms after the initial sound wave (aka no reflective surfaces within an inch), then that won't do much chaos inside the car.
    *crazy_boy
    Kindly do the separates -> deaden front doors muna. Then you can change your head unit and add an amplifier afterwards.
    *renz
    Go get a styro ball, cut it in half, drill some holes, mount your tweeter there then i-double-sided tape mo lang sa dash. Having a rounded and tapered back is important because of diffusion purposes and you have a MUCH smoother response than if you throw it sa box.
audio set-up for beginners [continued]
