Results 2,061 to 2,070 of 3070
August 25th, 2016 10:18 AM #2061
Is it the new Mazda3? I don't know how good the stock HUs of new cars are but the stock HU on my Fiesta Ecoboost and Forester XT are better compared the stock ones on our old cars (including the 2009 City and Jazz).
DLS and Morel speakers will be fine with a bit of juice (15-20 watts from stock HUs) but remember that you're building for a future audio modification. I had a DLS 2-way active setup before (DLS R6A powered by a DLS CA51 amp, plus an RF slim sub) in my old Exalta and I was very happy with it. My other NissanBayan friends have even better setups with DLS Ultimate, Morel Supremo, and Brax setups.
If you want speakers with a bit more sensitivity, you can opt for Focal models. I have heard good things about the newer PS line which they say sounds better than the Access models.Last edited by Egan101; August 25th, 2016 at 10:23 AM.
August 25th, 2016 12:41 PM #2062
August 25th, 2016 04:40 PM #2063
1. I wouldn't recommend a LoC; you won't need it.
2. Just get whatever speakers you're satisfied with.
3. Deadening follows the law of diminishing returns. To be honest, anything more than 1 sheet per door is overkill. And on a budget, doing a 50/50 on just one sheet for two doors isn't that bad either.
4. The only thing I like about Ryan is their more expensive speakers which has a certain character to them. Since you're leaning more of warmth, why not try Firland Audio's EV series.
August 25th, 2016 05:41 PM #2064
Ano 2 din head unit available na pwede mag mirror ng iPhone?
- Jun 2016
- 67
August 26th, 2016 12:10 PM #2065
- Jun 2016
- 67
August 26th, 2016 09:01 PM #2066currently, my amp is powering both the seps and sub. my setup was done by a car audio shop in las pinas. i was told by the installer that the crossover was set to -3db. i was looking for a more output from the tweeter so i brought my car to bp1 car audio in binan. the guy there told me that we need to put additional wiring because the first installer just used a sort of splitter. so the additional wiring was connected and he made some adjustments in my 5750bt hu and amp. the bass was softened and the sound was a little bit clearer. he advised me to replace my amp with dc 120 x 4 amp because my existing amp is overpowered by my firland ev612 seps that caused my amp to heat fast.
August 27th, 2016 02:19 PM #2067
Baliw naman pala ang 1st installer mo. Based on what you mentioned, it seems he only used one RCA cable and used a Y-connector to split the front signal of your HU for the seps and subs. The 2nd installer added another RCA cable so the front signal goes to the seps and hopefully the sub-out signal for the subs. Would you check if you can control the volume levelof your subs using the sub level control on your HU. Paki confirm muna bro before I continue. Let's see if we could do something 1st with the install before you spend for a new amp.
- Jun 2016
- 67
August 27th, 2016 04:59 PM #2068
August 29th, 2016 06:32 AM #2069
*ealdree
If I were to recommend an installer in Laguna, look for Reo at 2MC Audio (2MC Audio | Facebook). I'm not too sure if he still remembers me though
I cannot comment on your installation since it maybe alright but it may also still be in tatters. Why I usually recommend more well-known installers is because although they're more pricey in their services, you get that assurance that they get the basics correctly. At the very least, I have not heard a well-known installer have a project car go up in flames *cough* shots fired *cough*.
If you're changing an amplifier to a higher wattage one just because of heat, that's utterly wrong logic. The higher wattage you go, the more heat it emits as a byproduct of power conversion. Case to point: a 100W incandescent bulb emits more heat than a 50W incandescent.
What your installer is probably subtly telling you is that you need more power because of your subwoofer. If you're pushing it too hard, you might also be clipping the amplifier accidentally and this is bad for your speakers (it's the #1 speaker killer). Also partially because he wants to push you to a sale (it's their business after all, no harm in that). If I were to recommend, purchase a mono amplifier and make sure it's Class D in topology.
Brief Lesson:
Class AB -> 50-60% efficient -> aka, feed it 100W, 50-40W of energy is emitted as heat
Class D -> 90+% efficient -> aka, I am always cool to touch
Your Firland speakers do not need more power. In fact, feed it 50W and a lot of speakers are already happy. I usually tell enthusiasts that exceeding more than 100W is kind-of pointless.
Because of two reasons:
(1) Again, power is exponential. To make 50W sound TWICE as loud, you need 500W of power.
(2) Most speaker components cannot handle high power. Their voice coil might burn out (mechanical stress) and distortion increases dramatically the hotter you go (because heat affects magnetism)Last edited by jhnkvn; August 29th, 2016 at 06:35 AM.
- Jun 2016
- 67
August 29th, 2016 05:58 PM #2070
Tesla Philippines
