Results 2,321 to 2,330 of 3070
April 18th, 2017 06:19 AM #2321
- 53,883
April 18th, 2017 08:33 AM #2322avoid roads with humps?
but that would probably lengthen the trip.
we just have to live with it.
or, "tie it down" with hold-down clamps drilled into the metal.
if you do not want to have to drill some holes, look at the inside of the trunk for ready-made holes. see if you can pass bungee ropes over the sub, and hook the ends into these holes in the trunk. you will probably have to look under the trunk covers, to find the holes. you will probably have to drill holes thru these covers, also. those bungee ropes are available from hardware stores and malls. if you need more tension, simply make a few knots with the rope.
April 18th, 2017 09:03 AM #2323
- 53,883
April 18th, 2017 09:10 AM #2324
- Mar 2013
- 220
April 18th, 2017 10:23 AM #2325Madami humahabol pala lol. Jok!
Ano auto nyo sir sedan or hatch?
Type ng sub po?
May nabibili na swivel type na hook na pwede mo bolt-on sa nakaexpose na bolt or screws. SM, handyman, diy or simpleng hardware store. U could try also sa motorcycle accs. shop hindi mawawalan. Alternative pa is aluminum or plastic drawer knob dami mapagpipilian (diy lang) kung may access sa back panel ng paglalagyan for screws.....3M velcro, alam mo sir ung plastic na nakatahi sa 3M matting na para hindi dumulas sa carpet? Sa handyman ko ata nakita meron. Non slip pads na malaki or malapad pwede rin (gaya ng pangdashboard), Dining top rubber mat, etc
April 18th, 2017 01:32 PM #2326
- Mar 2013
- 220
April 18th, 2017 05:29 PM #2327From the trunk under the back glass or place ur rear speaker installed, may mga treaded holes na for 10 or 8m heads bolt na pwede mo kabitan, inner rear fenders kung baga eh tambol ang tawag ng latero magkabila hindi rin mawawalan. But if i were you sir magdrill ako ng kabitan sa rear brace ng cabin un ung nilalapatan ng backseat (sakto kung ano laki ng sub mo pa po).
April 18th, 2017 05:55 PM #2328
April 18th, 2017 05:56 PM #2329
Baduy ba pag sa rear deck ilagay ang amp?
Sent from my D5303 using Tapatalk
April 18th, 2017 06:23 PM #2330
