Results 1,211 to 1,220 of 3070
September 7th, 2014 05:57 AM #1211
September 7th, 2014 10:35 AM #1212
September 10th, 2014 08:56 PM #1213
Curious lang mga sir. I know that the bass frequency is 20Hz and below and that is the subwoofer's area.
My question is more in the component set. Given the frequency response of a component speaker A of 35Hz-21kHz and component speaker B has 60Hz-20kHz, does this mean that component speaker A will have better bass sound? Or, we also have to factor the materials and technology that has been used in the development of the speakers(w/ respect to near bass frequency)?
Please enlighten me. thanks.
September 11th, 2014 02:58 AM #1214
Q: Given the frequency response of a component speaker A of 35Hz-21kHz and component speaker B has 60Hz-20kHz, does this mean that component speaker A will have better bass sound?
A: Nope
Q:We also have to factor the materials and technology that has been used in the development of the speakers(w/ respect to near bass frequency)?
A: Yes. Engineering is expensive though, physics is a better indicator of bass. Larger midbass = more air moved = more bass.
Recreating bass or midbass frequencies is simply the art of moving air. Frequency response is a bad metric in general since manufacturers quote them vaguely. You see, all of these component speakers' midbass can technically reach up to 20hz once you remove the filters. BUT, you can't hear it since the output is too low.
September 11th, 2014 11:34 AM #1215
Got it sir jhnkvn. thanks.
So if there are 2 speakers with similar(but not the same) specs and only differ in woofer diameter like lets say a 6.5" and a 5.25", the speaker that has a wider surface area cone will be most likely have a better bass sound since it will move more air than the other.
September 11th, 2014 02:49 PM #1216
- Feb 2011
- 563
September 11th, 2014 04:56 PM #1217Had a Jazz before and to save space, what the installer did before was to create a false floor. Since malilim naman ang trunk ng Jazz they added an additional layer on top of the original flooring so the amp and sub is becomes an integral part of the flooring. Search mo na lang sa KAC my rides section
Posted via Tsikot Mobile App
- Apr 2008
- 6,235
September 12th, 2014 08:30 PM #1218May tanong ako. May problema yung stock head unit ng 2011 Santa Fe namin. Ayaw nya magplay ng kahit anong CD, lalabas lagi "bad disc", ganun din dun sa SD card slot, although tinatanggap naman niya ang GPS map data SD card. Yung TV niya 1 channel lang ang natatanggap. Gumagana naman ng maayos ang tuner at aux-in. Ano kaya problema nito?
Sent from my GT-I9100 using Tapatalk 2
September 12th, 2014 08:51 PM #1219
That's probably the head unit's "mother" board na mismo. In theory, it might just be the CD mechanism if lagi bad disc yun CD but since the SD slot is also affected, I'll suspect that it's the board itself.
Hindi ba pasok sa warranty ni Hyundai PH? Since that's going to cost a lot for repairs (almost brand new cost na yan)
- Oct 2008
- 525
September 14th, 2014 11:01 AM #1220Tanong ko lang, ganun ba talaga "ka-pangit" ang sounds ng stock headunits kaya need palitan if you want better sound? hindi ba puedeng lagyan na muna ng amps at change stock speakers? Ok naman kasi sakin yung tunog nung stock HU ng Vios 2013 pero yun lang need ko ilakas yung volume para may bass or mapuno nya ng sound yung loob ng car. Sa ganitong case ba ng listening style ko, palit HU ba ang better route?
