Results 51 to 60 of 62
- Mar 2013
- 6,160
February 2nd, 2022 11:32 AM #51Looking good. Cant wait for that update.
Sent from my SM-G998B using Tsikot Forums mobile app
February 18th, 2022 05:22 PM #52
March 17th, 2022 10:52 AM #53
May 9th, 2022 12:49 AM #54
Purchased AAWireless - which allows your wired headunit to connect wirelessly to Android Auto
AAWireless | Indiegogo
The unit is tiny and seems well made. To set up, simply download the companion app from the google playstore and follow the instructions. In my case, there were no problems with setting it up and setup was done in less than 4 mins. (I initially had some doubts if it would work, as there were some reports that some Xiaomi models have issues with it)
I'm using a Xiaomi Poco F3 phone paired with a Sony XAV-AX5000 head unit.
So far I've driven for a total of two hours and it works as advertised. I leave my phone in my pocket and it auto-connects and launches Android Auto on my head unit. Connection seems stable and si far I haven't experienced disconnections or interferences. Seems to work just as well as when I was using a cable (or maybe better, because before if i accidentally move the phone or the cable, AA sometimes disconnects).
The companion app offers a bunch of options in case you have connection problems, and also had a significant firmware update available (1.12 to 2.0). Since the unit was working great, I didn't change any settings on the companion app... nor did I update the firmware (yet).
There is a noticeable increase in battery drain though.
Will update if I start encountering problems with the unit.
April 16th, 2024 12:20 AM #56
Is it a bad idea to use a cheap android phone to be permanently connected to your car's android auto? Baka kasi maging source of fire pag ang kotse eh nababad sa init ng araw.
April 16th, 2024 09:35 AM #57
April 16th, 2024 11:45 AM #58
yung walang tanggalan ba? na iiwan mo sa car na naka park? parang any phone naman yata hindi maganda mababad sa init ng araw kasi may battery and other components.
saka pansin ko din kung naka connect either wireless or wired AA, medyo umiinit ang phone, parang nag g-games ka din.
- 53,883
April 16th, 2024 12:40 PM #60
yung akin naman... hindi yung init sa loob. yung convenience.
naka Android Head Unit kasi ako and for convenience ni misis, phone nya mag activate as CarPlay kapag nasa loob sya.
When I use the car, naka hotspot na lang ako and use the built-in Waze and Spotify (so technically, may 2nd device sa loob ng car)
when someone calls, I have to get my phone and manually activate the speaker
when I'm listening to music, uulit yung playlist ko when I use the car
tapos balos walang silbi si Siri since di lalabas sa screen yung voice commands ko.
